What Could Cause This Wear Pattern?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Aug 18, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    I'm thinking a broken belt. Every other major tread goove or lug pattern is stepped. It's the outside tires on each side of the rear tandem axle. What do you guys think?
  3. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Honestly, looks like you've gotten pretty good service out of those tires, I've usually replaced mine before they get that worn.
    austinmike and Diesel Dave Thank this.
  4. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I'm more concerned about the strange wear pattern.
  5. Volvo8873
    Volvo8873 Light Load Member
    239
    145
    Apr 27, 2016
    Western Wisconsin
    They look pretty good too me?
    Diesel Dave Thanks this.
  6. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Look real close and you'll see how every other row of lugs is higher or lower than the next. Also, the edges are wearing in a wave type pattern.
  7. Diesel Dave
    9,616
    32,370
    Jan 20, 2010
    Hesperia, Ca.
    It's called normal wear and tear. Beside it seems they had there life. I would be more concern on replacing them.
    When I start getting a funny wear pattern, I rotate mine, problem solved. When you buy your next set, stay away from anything that says made in China, Korea. I have stuck with Kelly's (USA) and had extremely good luck with them, but I'm local.
    JimmyWells Thanks this.
  8. miss elvee
    miss elvee Heavy Load Member
    816
    2,640
    Dec 15, 2012
    Russellville, AR
    If you run long distances, remember to check pressure on hot tires, not cold. They look slightly rounded in the pics, could be a bit over. Rotating really helps the life for outside wear. When's the last time you did a 3 axle alignment? Wavy edges have usually been alignment or pressure for us. Once it was a front shock.
    I understand running them thin, we do the same for fuel mileage in good weather, but I'd put new rubber on before the snow.
  9. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    There's nothing normal about that wear pattern.
  10. 201
    201 Road Train Member
    12,754
    26,238
    Apr 16, 2014
    high plains colorado
    I don't see much of a problem either, but I'm sure the pics don't describe it well. As tires wear down, they go out of balance slightly, a skid, hit something, cornering, tire pressure all contribute to uneven wear. It's a universal gripe, pal, nobody likes to buy tires.
  11. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I've always been taught to check pressures when cold and I run about 95 pounds on my drives. I've had the tandem aligned twice. Once after each side center hanger was done and I had the steer axle done not that long ago all at the same shop. I'm surprised a shock caused an alignment issue on your truck. since trucks have a solid front axle. I definitely plan on getting a few new tires before snow season.
    miss elvee Thanks this.
