What could it be?
Discussion in 'Ask An Owner Operator' started by zinita17601, Dec 8, 2020.
  1. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    2000 fld 120 3406e 2ws cat,truck dies while driving or idling randomely,gauges and lights stay on except speedometer and tachometer,
    If im idling i dont have to cycle the key,i just push the start button and if fires right back up.
    While driving and in gear it dies for a couple seconds and it starts again.
    No codes,no warning lights,full of coolant,less than a year starter and ignition relay.
    Dont mind spending money to fix it just need to know where to look.
    Any help is aporeciated
  3. 77fib77
    77fib77 Road Train Member
    11,597
    76,297
    Jul 7, 2010
    St Louis
    Battery start there. Then chase down wires and grounds.
    Roger McG and zinita17601 Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Look at wires leading from the crank and cam sensors care/fully and follow them looking for rub raw spots between wires and them rubbing on any steel?
    77fib77 Thanks this.
  5. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Do u know where these sensors at?
  6. Ridgeline
    22,715
    122,782
  7. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    Engine fires right back up,wouldnt a bad ground keep it from starting again?
  8. 77fib77
    11,597
    76,297
    Jul 7, 2010
    St Louis
    It's loose. Just a little bit.
  9. pavrom
    pavrom Road Train Member
    3,213
    7,399
    Apr 29, 2012
    NE illinois
    Try checking wiring on the ignition ...had same issue , truck was dying for no reason ( under load , empty , idling )
    zinita17601 and 650cat425 Thank this.
  10. AModelCat
    164,186
    If everything else stays powered up I would suspect an engine ECM power or ground wire issue.
    Dino soar and 650cat425 Thank this.
  11. rollin coal
    rollin coal Road Train Member
    13,577
    27,900
    Mar 29, 2008
    TN
    Pull the lid off of your battery box and check very closely the connections at the 15 amp fuse going to your ECM. Maybe some corrosion in there or loose and a poor connection? I dunno, just a guess on something to check and rule out.
    77fib77 and AModelCat Thank this.
