What cummins is this? ???????
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ntanner, Mar 17, 2016.
  1. Ntanner
    Ntanner Bobtail Member
    10
    Mar 6, 2013
    Hi, recently picked up a 1980 pete 359. Previous owner put current engine in it. He claimed it was a 350 big cam 3 but im thinking its a small cam. The data plate is ofcourse missing. Engine sn-32104951. Cummins quickserve only tells me it was originally built in may of 77(right in the changeover). The follower plates are small prolly 3-4" tall. So looks like a small cam. Except it has a pressed steel oil pan, and a pulse flow manifold, the aftercooler looks like big cam also. But then the waterpump is v-belt not serpentine. Engine has me confused but believing its simply a small cam. Any help is greatly appreciated. Thanks
  3. Ntanner
    10
    Mar 6, 2013
    I retract that last bit. The waterpump is serpentine not v-belt. Could all these big cam parts been put on a small cam? Is it some weird change over frankin engine updated to a bc3. Previous owner rebuilt 150k ago run believably so. But has big cam oil pressure 45 cold idle 30 hot idle
  4. EZ Money
    EZ Money Road Train Member
    Post it in the truck forums and someone can probably figure it out for you.
  5. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
  6. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    small cam engines have a compression release set up on them.
  7. Ntanner
    10
    Mar 6, 2013
    I don't have the cpl reckon tag was removed or fell off. I've been on the barrington site also. Follower covers look more like small cam. But small cam didn't have steel pans serpent belts or pulse flow. I see no noticeable compression release on this engine.hmm why do people let identification tags fall off.
  8. Diesel Dave
    9,635
    32,555
    Jan 20, 2010
    Hesperia, Ca.
    My Big Cam 1 says Big Cam on the block itself towards the backside on the drivers side. This is for a 1979 K.W., CPL 369
    Oxbow and wore out Thank this.
  9. 59MackB61
    59MackB61 Light Load Member
    196
    165
    Sep 12, 2012
    Should be on the block, like mentioned above as an 855 block could have had more than one rebuild over the years with changes to the belt drives and other bolt ons. Get the stamped serial number off the block and call cummins they will be able to tell you what the block was originally and the cpl. From that you can than figure out what it be built into
