What is DEF?
Discussion in 'PAM' started by Scoundrel, Oct 8, 2011.
  1. Scoundrel
    Scoundrel Light Load Member
    178
    35
    Apr 3, 2011
    Texas
    My co-driver and I have been issued a 2012 Cascadia with a tank for DEF fuel. We don't know what it is or how to use it. Our DM said to call RR, but I thought I'd get through here faster.
    So, what do we do with this?
  3. Drivin_Dave
    Drivin_Dave Bobtail Member
    14
    Oct 1, 2011
    Kentucky
    I'm sure someone will give you a more informative answer, but I understand it is an emissions control additive for 2011 and newer "Clean Idle Engines".
    If you're driving one you probably don't want to run with out it. I have been seeing DEF at Pilot stations where I fuel my company tractor in 2 gallon container and I understand it will be available at the pump soon in some locations.
  4. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    DEF = Diesel Exhaust Fluid
    Helps "scrub" the exhaust of black smoke and emissions. Trucks are "supposed" to run cleaner than cars now a days with all this emissions technology.
    Truckersmooth Thanks this.
  5. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Yeah, its pee(urea) and water. Lots of truckstops are putting it in bulk. But all sell the 2.5 gallon jugs. I say just top it off whenever you are at a bulk pump, and don't let it get below 1/4 tank.
  6. tirednaz
    tirednaz Heavy Load Member
    838
    430
    Oct 4, 2011
    Arizona
    Your truck has a gauge on the dash so you can monitor the level of the DEF it will warn you when you are getting low. Every truck is a little different on how much they will use so for awhile keep an eye on it.
  7. 25(2)+2
    18,759
    45,982
    Sep 18, 2006
    the road less travelled
    The DEF is added into the exhaust to reduce oxides of nitrogen, and reduces the need for EGR. It also allows use of a simpler non waste gated turbo in the new DD15, DD13, and DD16. I'm not familiar with other engines mechanicals that are currently being produced, other than the MaxxForce International engine which doesn't use DEF. I have heard of engines seriously derating, if the DEF isn't being added to the exhaust.
    It's supposed to restore efficiency to diesel engines that was lost due to EGR. The soot is taken out by DPFs in all current engines and back to the 2007 standard, if I remember it right. Those engines are in most trucks newer than 2007. DEF is newer than 2010.
    Loves has separate pumps, usually in one aisle, I've seen a compound pump with an extra hose for DEF at some Pilot locations.
  8. Dryver
    Dryver Road Train Member
    2,818
    2,576
    Nov 30, 2008
    Sioux Falls, SD
    OK, Here is a Mythbuster question I have heard around the truckstop.
    Why can't I just piss in the tank? The stuff we buy is only piss and water. I would like a company driver to try this method and report back with the results. It makes sense to me but what do I know.
  9. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    From what I understand def, or exhaust fluid (thought my trainer was pulling my leg, like blinker fluid or left hander screwdrivers) is used to clean the diesel particulate filters on newer trucks. The dpf catches the particulate matter in the filter. Eventually the filter becomes clogged. On our 2010 cascadia it just used normal diesel in a regeneration cycle to burn out the particulate matter clogged in the filter. I was told def is just ultrapure diesel made to burn cleaner in the regeneration cycle.
  10. 25(2)+2
    18,759
    45,982
    Sep 18, 2006
    You were told wrong.
  11. Noggin
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Even though its pee (urea), actual urine has other crap in it, plus the concentration would be way off. I wouldn't recommend pissing in your tank. Lol
