What is this thing?
Discussion in 'Flatbed Trucking Forum' started by Old Iron, Mar 2, 2016.
  1. Old Iron
    Old Iron Road Train Member
    1,158
    20,284
    Feb 19, 2011
    NW Wisconsin
    Not sure what this thing is. It's on a 2012 reitnouer step deck. The main red air supply line runs through it on the way the the air tank. An alcohol injection thingy? No electrical to it. Has a sight guage on it with "Max drain level". If it's a water separator I've never seen one like it before. Didn't have time to really investigate it yet.
    tmp_12880-IMG_20160302_174544200459679901.jpg tmp_12880-IMG_20160302_174517595-540675398.jpg
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Looks like it could be some kind of water catch can of sort. Looks like a drain on the bottom?
    Beyond that I have no idea.
    Glad I dont have that on my trailer. I'd be taking it apart just to see what it was.
    Hurst
    Cottonmouth85 Thanks this.
  4. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Looks like a binary explosive device
    street beater and Cottonmouth85 Thank this.
  5. Straight Stacks
    Straight Stacks Paper Cha$er
    2,930
    20,768
    Jul 18, 2015
    Alabama Gulf Coast
  6. Espressolane
    18,652
    116,848
    No,no, no that's not a thingamabob. It does not have an electrical connection. It's a thingamajig.
    Water separator
  7. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Easy. That's your circumdiscombobulator.
    ++ water seperator
  8. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Another vote for water separator.
  9. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    You don't need it, cut the weight
  10. thejackal
    thejackal Road Train Member
    1,359
    1,456
    Mar 1, 2014
    detroit mi
    Water separator for an airline in a body shop.
  11. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    That is simply a air oiler. It adds a small amount light whieght oil into the air system not enough to contaiminate the system just enough to lubricate upstream valves or controls. They are found a lot on snow plows, refuse trucks, and roll offs. Any truck that has remote actuated controls that activate hydraulic valves is common to have one of these on it. Basically it lubricates the O-rings on the air activation side of the hydraulic spool valve. Word of warning if you get curious and decide to open it make sure the air system is empty or you will get a face full of oil lol. After re reading your post Since it is on the trailer I think your right in saying its acting as a alcohol injector it would work for that aswell. Not a bad thing to have and use in cold months.
    dca Thanks this.
