What is wrong with this tire?
Discussion in 'Freightliner Forum' started by bigtire, Aug 15, 2012.
  1. bigtire
    bigtire Light Load Member
    117
    13
    Feb 19, 2012
    Las Vegas, Nevada
    Bad shocks? Bad tire?
  3. rookietrucker
    rookietrucker Trucker Forum STAFF Staff Member
    10,061
    7,059
    Jul 15, 2007
    TEXAS
    I can't quite see the inside thread but it looks worn. Does the steering wheel shake or do you fight with it going down the road ?
    Do you feel a shake in the seat going down the road ?
  4. bigtire
    117
    13
    Feb 19, 2012
    Las Vegas, Nevada
    It was shaking before, then I balanced the tires and put centramatics - now does not shake but still eating the tires. The mileage is 80 000. Tire make othzu, it says made in Japan, but could be some bad quality.
  5. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    Kingpin..................
    keepntruckin Thanks this.
  6. rookietrucker
    10,061
    7,059
    Jul 15, 2007
    TEXAS
    I agree, kingpin
    After replacing the kingpin and steer tire, I would get a 3- axle alignment. imo
  7. bigtire
    117
    13
    Feb 19, 2012
    Las Vegas, Nevada
  8. bigtire
    117
    13
    Feb 19, 2012
    Las Vegas, Nevada
    I have checked the king pins, only the driver side has a very small play, other side is good, but still eating both front tires?
  9. rookietrucker
    10,061
    7,059
    Jul 15, 2007
    TEXAS
    I had the same problem last year on freight shaker I was driving. Company put new steers on it and ate them within a month. Replaced the kingpins and steer tires, three axle alignment. Truck drove like it was brand new and fixed the problem. :)
  10. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    If your tires were already like that before you balanced them or did any work to the truck they will still continue to wear like that. They have already established a wear pattern and only way to change that pattern is to start back over with new tires and make sure everything else is up to par before putting any mileage on the new tires.
  11. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Your rears are out of alignment and pushing the steers sideways when you're going down the road. I've seen it a million times.
