what would you do???
Discussion in 'Freightliner Forum' started by buddyvuk, May 29, 2013.
  1. buddyvuk
    buddyvuk Medium Load Member
    337
    66
    Jan 6, 2013
    portland oregon
    I just bought a 2003 century 12.7 l and would like to know what would you guys do maintenance wise before heading out on the road.???? Should I change oil in differentials?
    truck has 800k miles
    this is what I did so far:
    - Ran dyno
    -Oil Samples
    -Mechanical inspection
    -Fresh dot
    -Oil change
    -Balanced tires
    What else would you add to the list?
    PLEASE NO ADVICE on running the business just on what other TUNE UP would you do to the truck
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    If you do not know maitanace hytory of truck - change all fluids
    buddyvuk Thanks this.
  4. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    P/S exuse me for poor spelling) was tired a bit) LOL
  5. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    When was the overhead set last?
  6. gieser
    gieser Bobtail Member
    9
    May 29, 2013
    send in a sample for coolant analysis
  7. gieser
    9
    May 29, 2013
    also take it to a Freightliner/Detroit dealer and have the DDEC Reports printed off (all of them) and reset
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,212
    Jan 7, 2013
    On top of a full inspection and fixing what we find wrong, we:
    change all fluids/filters with oil samples
    Air Filter(s)
    drain some fuel from the bottoms of the tanks (check for water, trash, etc.)
    HVAC filters and clean condensor and heater cores if needed
    Pull A/C condensor and/or CAC to get a good look at and clean the radiator/CAC/condensor
    air dryer service
    load test batteries
    remove/clean all battery/starter connections
    check alignment
    full check of the A/C system and inject dye if it doesn't have it
    valve adjustment
    set ECM parameters to our spec
    reset any driver trip info and clear inactive codes (engine, ABS, and any other ECU that will store faults)
    Since we run PTO hydraulics, if the truck has a PTO we'll pull the pump and check splines (common wear point).
    Road test
    Basically, since we didn't do the service, we can't be sure 100% that any records are accurate, so we have a fresh start.
