whats going on with this ABS light
Discussion in 'Volvo Forum' started by dphillips, Jul 16, 2015.
  1. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    I have a 2007 Volvo 670 and the abs tractor and trailer lights aren't coming on when I start the truck. but when im driving and hit the breaks ill see the trailer abs light come on with some trailers.so I thought maybe the tractor abs light died. but then I did a self test on the instrument cluster and the light pops on. and I know the abs light on the tractor should be on because I had the truck scanned for something else and the guy said you have 2 abs sensors out one on both sides.
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    When the trailer abs light comes on during braking it usually means the primary power circuit is dead. Big pin in the middle of your pigtail sockets. It should have power any time your key is on.
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    check in the instrument cluster if you can communicate or read the fault codes for the abs ecu if you can't there is a very good chance someone removed one of the fuses for the abs system when you look at your fuse diagram you should have an abs1 and abs2 fuse both 15 amps check them out and let me know if you need anything else with it
    dphillips Thanks this.
  5. waltherz
    waltherz Light Load Member
    133
    13
    Dec 12, 2012
    Like KeithT1967 said, is electrical problem, check both male plug of green cable. I had same inconvenient: the connectors inside of male plug was rusty. Truck stop has aluminum plug by $12 and it fix the problem.
  6. dphillips
    82
    8
    May 14, 2013
    Yeah I checked both of the fuses abs1 had power going to it when the truck was off. I had to turn the key on to get power to abs 2. a little background when I first went for the truck the tractor abs light was on I told the dealer. I came back a week later and thought nothing of it as the light was not on. I had an inspection and the guy said your abs light should be on as you have active abs codes but no light. I thought maybe they removed the bulb. so I did a light test on the instrument cluster which makes all the light come and both the abs tractor and trailer lights came on which means the bulbs are there.so why not when I start the truck as I have a active abs sensor fault.
  7. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    so next thing is it's possible someone disabled you're abs light at the dealer with a computer so that would be the next thing you would have to check
