Wheel seal problem
Discussion in 'Experienced Truckers' Advice' started by supergreatguy, Jan 5, 2021.
  1. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    What would cause the inside of the wheel to leak? Had parts swapped last week, inner and outer bearing and seal
    jamespmack Thanks this.
  3. supergreatguy
    1,030
    2,896
    Nov 26, 2020
    Called mechanic: he said if the wheel seals leaks onto the brake pads and drum I should swap pads and drum due to soaking/fire hazard. True? Or he pulling a fast one?
  4. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    It’s leaking because the new seal failed, improperly installed, it’s cheaper to replace shoes than pay shop time to clean. Brake drums can be cleaned.
    Did mechanic offer any warranty?
    jamespmack and Final Drive Thank this.
  5. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    He installed the wrong seals, or damaged new seals on install, he should cover the cost of labor and seals. Ive never cleaned drums and brake shoes on a wheel seal leak, never had an issue.
    jamespmack and Bean Jr. Thank this.
  6. bad-luck
    bad-luck Road Train Member
    3,426
    6,310
    Nov 16, 2013
    Baltimore, Maryland
    Drums are easy to clean. Just use starting fluid, or break cleaner
  7. supergreatguy
    1,030
    2,896
    Nov 26, 2020
    it was my uncle so I get that family warranty haha. Am I missing something about understanding the wheel seal? Why would it leak from inside the wheel area if the seal is towards the outer part of the wheel?
  8. jamespmack
    216,471
    Hubcap or axle flange is outter. Wheel seal is inboard. Np cleaning a drum. Shoes need to be replaced.
    pushbroom Thanks this.
  9. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Nope you can safely clean the shoes also..
    snowwy and Bean Jr. Thank this.
  10. Hulld
    Hulld Road Train Member
    2,884
    6,568
    Oct 19, 2015
    Upstate NY
    When ever I had that issue I would steam clean the #### out of them and then brake clean and blow dry.
    Zero issues doing it this way in well over thirty years.
    Also if the hub vents are restricted or blocked the wheel seals can leak.
  11. jamespmack
    216,471
    The old debate, have I done this for dealers, customers and employers? Yes. But if your that cheap, that you can't afford new shoes. Your broke. No oil soaked brake lining should never be reused. While I still do side work, if you request this you need to find a new shop. I'm not doing it.
    Flint1 and pushbroom Thank this.
