When is a 53' Step, a 53' Step?
Discussion in 'Flatbed Trucking Forum' started by Blind Driver, Mar 1, 2013.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I lost a load a few weeks ago because my step measures 51.5'. The customer wanted a 53' step. Should I have embellished and went after it anyway? The agent told me they had to have 53' of trailer.
    That load paid $2.64 a mile for 1100 miles and was 90 miles from me.
  3. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    51.5' < 53'. If they wanted a 51.5' trailer, they would've asked for one. You could have told them you had a 53' trailer and played dumb about it and seen if they'd load you, but what if you got there and came up 1.5' short of being able to haul the full load? You would have driven those 90 miles for nothing....possibly wasted a bunch of your time (and theirs) while they attempted to load you and then pulled their freight back off your trailer if they took your word for it and didn't measure it....and you still wouldn't have been able to run the load.
    If you wanted to haul loads requiring a 53' trailer, you should've bought a 53' trailer.
    kerosene jockey Thanks this.
  4. UTI TRANSPORT
    UTI TRANSPORT Light Load Member
    126
    53
    Nov 16, 2012
    All my shippers consider anything under a 53' er a 48' trailer and from my experience those 51's and 52's are heavy anyways and can't get the weight on them that the shipper wants. So better to be honest and save a lot less headache.
  5. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    It really depends on the trailer manufacurer and the specs to be honest. I can scale a 48000lb load with at 50ft step loaded up with all my equipment...but I can only scale that load in IA, NE, KS, OK, ND, and SD because I run 86000lbs gross in those states. Anywhere else ain't going to happen heck even a 48 step is pushing 48000lbs lbs of payload and there's only 2000lbs difference in the trailers.
    UTI TRANSPORT Thanks this.
  6. BAYOU
    BAYOU Road Train Member
    2,847
    1,592
    Sep 23, 2010
    Beaumont,Tx
    You should of called and ask questions most the time when there looking for a 53ft trailer its because they need a 40ft bottom deck. i have a good buddy that has a 48ft 8ft top deck and 40ft bottom he is the one that told me call on them and see he does lots of 53ft loads on his 48
    SHC Thanks this.
  7. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Our agents have been trained pretty well most of the time, when they say that the load requires a 53' trailer they mean it. Otherwise the load on the screen would have only said that it needs a 40'+ bottom.
  8. dhooks
    dhooks Light Load Member
    159
    52
    Jun 25, 2012
    Always ask how much bottom deck they need, thats usually the kicker.
    A shipper loads a 48 with a 37ft bottom deck one time and they automatically assume they have to have a 53
  9. Cluck Cluck
    Cluck Cluck LTL Wizard
    3,795
    3,480
    May 6, 2010
    Dunkirk, Indiana
    Showing up with a 51.5' is a lot better then showing up with a 45' 96" flat
  10. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    That would be a 53'er. PERFECT!!!!
  11. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    Yeah, most the time they ask for a 53' SD because they need 40' of bottom deck. The load I have now was listed fr a 53' SD (and pays accordingly) and the customer needed 40' of space, but since I have the 41' bottom deck it worked out. Always call and ask
    BAYOU Thanks this.
