When to change?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by HalpinUout, Sep 16, 2017.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    I have 10k on the filter that's on the right... Generally change oil every 15k... At what point to I determine I should change that filter out between oil changes? I took it off today so I could access a leaking air line and figure I would ask... Is my fuel mileage being affected by such a dirty filter? 20170916_121857.jpg
  3. mitrucker
    mitrucker Road Train Member
    5,456
    10,185
    Dec 15, 2010
    Lapeer, MI
    I say just change the filter with the oil. In this situation though, since it's already off, change it.
    Keep in mind that I am just a company driver though. I don't have to worry about that kind of stuff.
    HalpinUout Thanks this.
  4. ladr
    ladr Road Train Member
    1,383
    15,431
    Apr 14, 2013
    GA
    Doubtful if your fuel mileage is being effected enough to warrant changing.
    stay on schedule
    mhyn and HalpinUout Thank this.
  5. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    I change it every 50k miles or when fuel level reaches to top edge of label. this is 10 micron filter.
  6. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    Dude! That filter is horrendous! Looks like you either have an algae infection or an asphaltene issue. I would start with a biocide, shock the fuel and continue to use until tanks and lines are clean. You may have to change fuel filters, both of them, several times between oil changes. I can only imagine what your other fuel filter looks like if you were to cut it open. You need to get on this ASAP. NAPA or any truck stop will sell the biocide. And it is not a one time deal, you may have to spend a moth or two on this issue to clear it up.
  7. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    ))))))))))))) don't scare him. there is no algae infection or an asphaltene issue.. it's a soot , the engine has little worn injector O-rings. I guess he has 14L series 60 or pre-2007 isx. if it's a 14 L series 60 google for black fuel issue.
  8. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
    If that is soot in his fuel as you stated, he has larger issues than an algae or asphaltene infection.
  9. mhyn
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    yes. new O-rings for injectors and injector cups...
  10. Justrucking2
    3,211
    4,295
    Sep 12, 2017
    Plymouth MI
  11. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    It's really very simple. You change that filter when the fuel level gets to that black stripe on the top end of filter.
    That's why you run a davco. Your not gaining anything by changing it earlier.
