Where do I start (again)?
Discussion in 'Ask An Owner Operator' started by Wildcat74, Dec 20, 2011.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    Last winter I filed for and recieved my USDOT # and MC #'s thinking that I was going to get out and do some OTR stuff. Long story short I decided to put it all on hold and stick with my daycab and end dump business for one more year to see if it got any better. Lo and behold this year has been another disapointment, haven't stayed near as busy as I had hoped to again. I've got the funds saved up to buy a clean older OTR truck and dry van and have been looking into doing so. After spending some time looking around I've decided I don't want to lease on to a company for many reasons and I'm ready to run under my own authority.
    Several months back I was called to get set up with a safety audit but notified DOT that I had changed my plans a bit and wasn't going to run OTR anymore at that time. I beleive they said that was fine and that they would put my numbers on hold or something to that effect.
    Sooooooo long story short, being where I am how do I go about getting the wheels on all of this turning again? Should I acquire a truck & trailer first and foremost and then get on with everything else or ??? I had things all figured out in a linear process last year but having walked away from it for a year I'm kinda lost on where to start again.
    What I already have : CA# for running CA intrastate
    MC#
    USDOT#
    Fed Emp ID #
    BOC-3 filed
    IRP was paid
    Now what?
    Thanks in advance.
  3. BigBadBill
    BigBadBill Bullishly Optimistic
    4,599
    4,439
    Oct 2, 2010
    Chattanooga, TN
    Ok, for what you are asking I am not sure. I would say contact FMCSA and see what they about starting up again. May be whole new filing.
    But how long are you going to be able to run in CA with an older truck without bringing it up to compliance? I'm from CA and still have strong roots there. All my trucking contacts are getting out or getting newer, expensive trucks so they can keep running.
    CARB is set and courts have ruled.
    Gears and SHC Thank this.
  4. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    CARB is kiiiiinda set. They're waivering about the deadlines some and with the economy being what it is I don't know that the state can make it happen. Last week I had my CA BIT inspection and the CHP inspector said straight up that CHP was goign to do everything it could to not enforce the new rules. We'll see what comes of that though.
    That being said, if they pull the trigger on it all I'm leaving the state, plain and simple. I can't afford a '10+ truck and more importantly I don't WANT a '10+ truck. My end dump rig is an '83 Pete 359 with a 3406B and I'd like to get into a truck with a 3046E or N14, maaaaybe a 12.7 if it's the right truck.
  5. Diesel Dave
    9,531
    31,597
    Jan 20, 2010
    Hesperia, Ca.
    What BigBadBill said But, don't go into Van's, stick with Flatbedding, even OTR. If you want to cheat, go with a Curtain Van
  6. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    Are the rates THAT bad in van right now?? I am not opposed to flats which I've done some limited work with here for the construction companies I work for, and I know the rates for flats are generally better than vans on the whole, but it's mostly been hauling big concrete blocks and various lumber and pipe. I've got to admit, having never been taught the "truckers ways" of securement and tarping just makes me a little nervous about flats though.
  7. LSAgentOZR
    LSAgentOZR Road Train Member
    2,043
    1,354
    Nov 1, 2011
    Nashville, TN
    What Bill said, but my question to you is this... Why go through all the BS of having your own MC and factoring and blah blah blah, when you can sign on with Schneider Choice or become a BCO with Landstar and pay them a percentage and they take care of all of that headache for you so you can run and make the money?
    I'm still not quite sure I understand that aspect of it. Probably never will since I don't have a CDL and don't plan on owning my own trucks anytime soon.
  8. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    A) I haven't driven OTR for just over 2 yrs now.
    B) I don't want someone telling me when/where to run (which I understand LS and SNI Choice give you options there, but I don't know that I would qualify for them at this point. I've also heard SNI Choice isn't available to those based in CA for whatever reason)
  9. ultraclassic
    ultraclassic Light Load Member
    205
    71
    Aug 4, 2011
    Oklahoma City, OK
    "but it's mostly been hauling big concrete blocks and various lumber and pipe" @Wildcat74 - You need to go to the new flatbed section and look at some of the pics. A LOT more than blocks, lumber and pipe being hauled down the road on a flat. And its very challenging, at least to me...
  10. Diesel Dave
    9,531
    31,597
    Jan 20, 2010
    Hesperia, Ca.
    Landstar requires 1,000,000 liability, 100,000 cargo and your own authority and your CA # qualifies for cali only which they have work there to.
    Wildcat74 Thanks this.
  11. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    I wasn't bragging about hauling these items, quite the contrary as a matter of fact...
    I didn't realize LS had a deal like that, I will definitely look into that. Thanks a ton for all the pointers you've provided me with tonight DD, much appreciated.
