Where is the fire....
Discussion in 'Truckers News' started by bad-luck, Mar 23, 2023.
  1. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
  3. The Green Mountain
    The Green Mountain Light Load Member
    248
    2,095
    Nov 24, 2022
    Maine
    Well... When those tires shred and the driver rolls on nothing but rim for 25 miles.... He's kinda prepared.
    Fire extinguisher: check!
  4. Flat Earth Trucker
    4,313
    16,551
    Nov 19, 2018
    This is going to save dogs some trouble seeing as how the fire hydrant is between two tires.
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Dog won't know where to aim.
  6. drvrtech77
    drvrtech77 Road Train Member
    15,477
    151,485
    Mar 20, 2010
    201 Road Train Member
    12,764
    26,262
    Apr 16, 2014
    high plains colorado
    Never know what will get caught up in the duals,,I've picked up a lot of wagons, I don't recall a fire hydrant stuck in the tandems, someone got some 'splanin' to do. Shouldn't be too hard to find where it came from with the impending geyser it created. I'd say pressure a bit low in that area.
    hope not dumb twucker Thanks this.
  8. SmallPackage
    5,777
    18,542
    Dec 20, 2019
    Marion Texas
    Yellow painted hydrants in our area mean they are connected to a pump upstream that has to be turned on to supply it. So ripping one off its base wouldn't cause a geyser.
    Red is full time high pressure.
    Black is full time low pressure.
    hope not dumb twucker and REO6205 Thank this.
  9. REO6205
    REO6205 Road Train Member
    13,168
    60,499
    Feb 15, 2014
    California.
    If you get careless with a D-6 in Colusa County California a fully charged hydrant and three joints of supply line on either side of it cost $6500 bucks to replace . That was in 2001. And no, I didn't fire the Cat skinner. :rolleyes:
    OLDSKOOLERnWV and Rubber duck kw Thank this.
