Where's the coolant
Discussion in 'Volvo Forum' started by mikey747, Jan 2, 2017.
  1. mikey747
    mikey747 Light Load Member
    60
    20
    May 13, 2016
    I have a 2007 Volvo with a Ved12, my truck shut down for low coolant but when I checked the expansion bottle it looked fine, so I flushed out the bottle and put a new probe on it. Well it shut down again saying low coolant on my dash warning screen. Is there another sensor for coolant levels on this truck?
  3. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    I would say maybe the sensor harness is messed up...do a wiggle test and follow the wires as far as you can to locate any loose connection
    especially if you already swapped out the old sensor with a new sensor
    mikey747 and CoyoteExpress Thank this.
  4. Numb
    Numb Crusty Curmudgeon
    4,309
    10,226
    Jan 30, 2012
    Charlotte, N.Carolina
    had an '08 and it had 2. one at top and one somewhere on the bottom,I think it was.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    there is only the sensor under the bottle sometimes the level looks fine when you are driving but when you make a turn coolant shifts and it shows low coolant just for a moment enough to shut the truck off
    mikey747 Thanks this.
  6. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Unplug sensor on tank loop a piece of wire into it don't plug it back in and it wont shut down anymore
  7. mikey747
    60
    20
    May 13, 2016
    Thanks to every on that replied, lots of good info.
