Where's the coop?
Discussion in 'Experienced Truckers' Advice' started by Mrh2008, Nov 5, 2013.
  1. Mrh2008
    Mrh2008 Road Train Member
    1,288
    310
    May 25, 2012
    Mesa, AZ
    I'm running Vegas to Bakersfield in the morning. I'm at 80,060 pounds. Haven't ran out here in a while, is there a NV/CA coop yet? I'd look in my atlas, but it's the 2011 edition. No help if there's a new coop. I heard there was one going up at the NV/CA line on 15.
    if I remember, the only coop I'll cross is the one on CA58 near Tehachapi. Right?
  3. sixthgear11
    sixthgear11 Light Load Member
    197
    192
    Sep 24, 2011
    myrtle beach, sc
    You'll lose 60lbs in fuel weight before you hit the scales... Besides that, the scales give a slight margin of error on their equipment, so a few lbs over they're not gonna ticket you over
  4. Mrh2008
    1,288
    310
    May 25, 2012
    Mesa, AZ
    True, was just wondering where the scales are. I only recall one, tehachapi. Am I drawing a blank? There's nothing between here and Barstow except produce inspection outside Baker I believe.
    i plan on losing at least 200 pounds between here and tehachapi.
  5. dca
    dca Road Train Member
    6,834
    11,428
    May 31, 2011
    Earth
    Yes the 58.. you'll lose the weight in fuel if it's on the drives ... 8 pounds per gallon
  6. Mrh2008
    1,288
    310
    May 25, 2012
    Mesa, AZ
    I pull a 10' spread flatbed, all axle weights are good.
  7. Mrh2008
    1,288
    310
    May 25, 2012
    Mesa, AZ
    No way I was going back to untarp for them to take 60 lbs off me!
    If only I weighed what I did before I started driving... :biggrin_2554:
  8. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    You worry too much :biggrin_25517:
    Skydivedavec and 123456 Thank this.
  9. Mrh2008
    1,288
    310
    May 25, 2012
    Mesa, AZ
    That may be true! I've never been over gross, just covering my bases!
  10. dca
    6,834
    11,428
    May 31, 2011
    Earth
    70 miles ought to place ya under gross tho 60 pounds is 60 pounds ... now
  11. Moosetek13
    Moosetek13 Road Train Member
    14,975
    19,013
    Nov 1, 2010
    Burnsville, MN
    Maybe, after 3 years, you should invest the big bucks and buy a new atlas?
