Which older cats WILL work with eld?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by tnc110, Mar 20, 2018.
  1. tnc110
    tnc110 Light Load Member
    135
    81
    May 22, 2016
    I understand that elogs will work with some older engines and some will not. I'm looking at having a c16 built. I would like to be exempt, but still be able to run elogs if I lease on with a company that required elogs. Which models will work with elogs. Is the 1mm 1999 the only c16 that would work?
    UnderwoodInc Thanks this.
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Any electronic engine should work with elogs. If it has a diagnostc port should be fine.
    AModelCat and Oxbow Thank this.
  4. tnc110
    135
    81
    May 22, 2016
    Carrier I am talking to says that some of the older trucks don't work.
  5. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I would get in touch with the elog manufacture and ask them.
  6. AModelCat
    163,592
    I would think it depends on what protocol the vehicle runs under. J1939 is the current standard and has been in use from the late 90's/early 2000's to present. Prior to that I believe it was the J1587 protocol that was used by heavy trucks. Not sure what standard an older Cat uses and what elog devices would be compatible with it though. Like Swaan said, might be best to call the manufacturer and find out.
  7. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    I have a friend with 2 trucks
    1 is an 07 international with a cat C15
    the other is a 97 W900 L with a 12.7 60 series detroit.
    the ELD will not work on the detroit. numerous attempts at a remedy and it's a no go
  8. tnc110
    135
    81
    May 22, 2016
    This is what I'm trying to avoid! About to dump a ton of money into a glider. Would hate to build a 200k truck and not be able to work it.
  9. dirthaller
    dirthaller Road Train Member
    1,124
    13,274
    Sep 22, 2011
    Coloratah
    If your cat has a 7CZ serial #, you’ll be fine.
    wore out Thanks this.
  10. tnc110
    135
    81
    May 22, 2016
    I was hoping to build a 1mm. They are 70 pin ecu. the 7cz is 2000 and newer. .. Not elog exempt.
  11. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    1mm will work.. same ecm as 7cz and 2ws and 6nz.
    dirthaller Thanks this.
