why do i have diesel going into my oil
Discussion in 'Mack Forum' started by tonkamack, Jul 7, 2012.
  1. tonkamack
    tonkamack Bobtail Member
    2001 mack vision 13spd 460
  3. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    <why do i have diesel going into my oil
    2001 mack vision 13spd 460 >
    sounds like a bad injector. ​
  4. tnt440
    tnt440 Light Load Member
    98
    29
    Apr 29, 2012
    Wisconsin
    cracked head
  5. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Injector o-rings
  6. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    injectors one or more are leaking
    . dont delay fixing it your washing down the cylinders with diesel
    it is only a lubricant in an injection pump
  7. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    When you say fuel, how much are we talking? If it is very small amounts, do you idle your truck latley with this heat? That can cause cylinder washdown because of no load being put on the motor.
  8. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    might need to raise the rpms while you are idling also
    milskired Thanks this.
  9. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    putting the fuel in the wrong hole
  10. TRUCK3R M1KE
    TRUCK3R M1KE Light Load Member
    168
    157
    Jun 27, 2012
    Spokane
    As others have said, injectors or injector o-rings.
  11. x#1
    1,773
    1,104
    Dec 24, 2009
    that's what she said
    tnt440 and bender Thank this.
