Why does my compressor keeping kicking out?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dave_in_AZ, Nov 2, 2019.
  1. Dave_in_AZ
    423,392
    Tanks are full. No pressure drop. Kicks off, or tries to about every minute or two.
    This is an intermittent condition.
    Changed the governor to no avail.
  3. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Are you talking about the air dryer spitting?
    Dave_in_AZ, PE_T and bzinger Thank this.
  4. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    Sounds like time for a new air dryer Dave.
  5. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    Its suppose to cut off when the tanks are full... its not suppose to keep pumping air into them until something explodes...
  6. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    You need to check either the the air line between you governor or the unloader in the compressor is gummed up and sticking.
    It sounds like your drier is operating correctly.
    Rideandrepair, Dave_in_AZ and 062 Thank this.
  7. Dave_in_AZ
    423,392
    The burst of air comes from the air dryer location.
    Seems to do it when I change altitudes as well.
    Just acts up for awhile then nothing. Truck is pretty tight for air leaks. Then it'll start kicking off with full tanks like every minute for awhile while both tanks are at 125.
    062, Rideandrepair and bzinger Thank this.
  8. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    If your dryer is mounted where mine is ( behind the bumper ) it catches all the salt and crud and will be corroded to heck and the bolts will break in the housing .
    Took mine off and pitched it in the scrap pile .
    New one was cheap from kenworth.
  9. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Dave,
    What dryer do you have? ADIS?
    If yes, purge is controlled within the dryer. Needs a dryer.
  10. Dave_in_AZ
    423,392
    I'll have to check the make / model. Probably the same one Brad has. Would the filter being clogged cause this?
  11. bzinger
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    Mines a bendix .
    Not sure on mine ...after the 2nd bolt bolt broke ..threw it away .
    Rideandrepair and Dave_in_AZ Thank this.
