Wide Load Vs.Harvester
Discussion in 'Trucking Accidents' started by mjd4277, Sep 17, 2025.
  1. Truckers Report Jobs
  2. Flat Earth Trucker
    4,313
    16,566
    Nov 19, 2018
    @TripleSix please inform your brethren that it is quite rude to knock around a combine.
    mjd4277, JonJon78 and Numb Thank this.
  3. AModelCat
    164,604
    Well I'd be surprised if that combine had less than $200k in damage.
    mjd4277 and Flat Earth Trucker Thank this.
  4. TripleSix
    133,273
    @Rontonio this is a 2 lane trailer on what is probably mostly 2 lanes. shouldn’t there be a front car? Has to be 20ft wide.
    Lead truck can’t see anything behind and the push truck can’t see anything.
  5. MacLean
    MacLean Road Train Member
    1,380
    4,090
    Sep 12, 2017
    Good on the Farmer. For years I’ve said they’re the most dangerous people on the road. 11.5 wide, 25 mph and just rolling down the side of the road living their best life with no permits or trucks moving their equipment and using escorts. If a driver tried anything a farmer does he’d be in prison.
  6. Trucker61016
    Trucker61016 Road Train Member
    1,576
    4,547
    Sep 18, 2017
    Linville, Va
    Well this was dare I say, a bad
    Combine-ation
  7. Rontonio
    Rontonio Road Train Member
    6,483
    47,863
    Aug 9, 2009
    it is a 64 wheeler in Canada - almost certainly in Alberta somewhere. So it is a different world so to speak - probably under 16 wide. Likely a 12 wide triple 16 trailer, With extra dual wheels added to the outside. The little bit I saw was a 3 lane setup.
    It looks like he went to pass and then an on oncoming popped up and he had to squeeze.
    The driver showed some impatience trying to pass and the farmer did what some farmers do - refuse to give even an inch.
    so both of them are to blame - no accident if the farmer gives a little room when he knows the load is going past and the driver chose poorly (even though he tried to do it in a 3 lane section- which are few and far between)
    that’s my take
    kylefitzy, TripleSix, mjd4277 and 3 others Thank this.
  8. AModelCat
    164,604
    I figured either AB or SK as well.
  9. TripleSix
    133,273
    The widest I pulled in that area was a 16 wide pipe rack out of AbileneTX. Saskatchewan told me that a pilot car wasn’t required. Alberta required the pilot car on a 2 lane. Of course, you run the pilot car to the front on a 2 lane. I see the pilot to the rear in the video.
    Anyway, thanks for the info.
  10. Rontonio
    6,483
    47,863
    Aug 9, 2009
    he may have not been running a pilot car as much as a rear Steerman.
