Wierd clutch problem.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bigguns, Mar 15, 2020.
  1. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    I put an Eaton Easy Pedal clutch in my truck. Then I bolted the transmission up to it. The throw out bearing is back against the clutch brake and not up near the fork. The clutch linkage and forks are correct. The bearing isn't hung. I can take a small pry and easily move the bearing forward. What is wrong?
    Rideandrepair Thanks this.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Are you sure the fingers on the forks are inside the two ridges on throw/out bearing that keep it from falling out of throw/out bearing, you will have to unbolt the trans and slide it back some till you can get forks in slot in throw/out bearing then care/fully slide trans back up to eng. watching as it get close to be sure forks dont slip out of place?
    bigguns Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Clutch discs in the wrong order could cause that. I did see one incorrectly marked once.
    SAR and bigguns Thank this.
  5. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Newer Eatons come assembled (making them he77 to get in. You put in the first disc. It is marked flywheel side. All the rest is one unit.
    The forks are in front of the bearing. The cross shaft turns easily.The bearing isn't hung. It can easily be moved forward toward the engine.
    The adjuster can't be moved on either direction.
  6. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Never have seen it, but manual states to call support center. Used support center with Ultrashift problems and usually pretty helpful. Screenshot_20200315-210114.png
    SAR, bigguns and Goodysnap Thank this.
  7. Rideandrepair
    17,548
    56,858
    Aug 8, 2015
    Did the little blocks of wood fall out,when you bolted in down? They must have, if you can move it.?
  8. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    When the bolts were very close to tight the blocks of wood fell out.
    I tried a couple of pics but they aren't worth trying to unload.
    I called the help center at 5pm east coast time. Sorry can't help you. I was told it is after hours and I would need to talk to a senior advisor.
  9. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    I messed up. Step #7. Didn't do that as a step in the procedure.
    I know the blocks of wood aren't very thick and 1 fell out. The other dropped out at the last second. So I would say the bearing was at the proper distance. Something went haywire later when putting the tranny in.
  10. Rideandrepair
    17,548
    56,858
    Aug 8, 2015
    Mid America clutch has a video on clutch adjustment, might help, One part talks about the throughout bearing sleeve getting off center. Prying bearing towards clutch to center it up. Adjuster not working? Blocks came out good, like they’re supposed to. I’m sure you’re holding pedal in, while trying to adjust it. Does it move it up against clutch brake, when depressed? If not maybe adjust linkage to compensate. I’ve only done 1 clutch, with a bunch of help from Boxcarr Kid. No expert. Just trying to help.
  11. bigguns
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    With the pedal to the floor it doesn't touch the throwout bearing. It is close but doesn't touch it. I will watch the video. I have nothing to loose.
