Will it work.
Discussion in 'International Forum' started by circle h, Jan 4, 2024.
  1. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    I have a 2009 7400 with a maxxforce dt and an 8ll. A neighbor has a 2000 4700 with a dt466 and an automatic. He threw a rod and will sell me the truck cheap. I need the hood for my 4700 and can use one of the doors for another truck I have. My 7400 is an old railroad truck so it's all about the welder, air compressor and crane. It doesn't go more than a few thousand miles a year. It needs a clutch and no one around here likes the engine trans combo. The 4700 has a cable shifter, not electronic. So the big question is can I put the allison from the 4700 in to the 7400? I won't know what trans it has until I talk to the parts guys at my dealer in the morning. Vin of the donor is 1HTSLAAM0YH276430 in case that helps
  3. Chinatown
    Chinatown Road Train Member
    77,660
    184,031
    Aug 28, 2011
    Henderson, NV & Orient
  4. Inderjit
    Inderjit Heavy Load Member
    768
    735
    Sep 17, 2017
    From Navistar's site.
    TRANSMISSION, AUTOMATIC {Allison AT-545} 4-Speed; Includes TC-290 Torque Converter, PTO Gear and Transmission Oil Filter; and Less Retarder
    circle h Thanks this.
  5. circle h
    240
    375
    Oct 22, 2020
    Thanks for this. How did you do that? I search Navistar and can't find a vin decoder. My service truck is 1HTWCAAN29J188290 The at545 and tc290 are only good for 235hp and 330 ft lbs of torque. I am guessing I make a lot more than that, but am not sure.
  6. Inderjit
    768
    735
    Sep 17, 2017
    I work for a dealer and have access to their site.
  7. Inderjit
    768
    735
    Sep 17, 2017
    Your engine spec from your VIN:
    ENGINE, DIESEL {International MaxxForce DT} EPA 07, 260 HP 800 lb-ft Torque @ 1400 RPM, 2400 RPM Governed Speed, # 2 Bell Housing
  8. circle h
    240
    375
    Oct 22, 2020
    Thanks, I appreciate it. Last thing I need is someone else's problem sitting around.
