Wilson Trucker 2000
Discussion in 'CB Radio Forum' started by Dark Squall, Feb 19, 2015.
  1. Dark Squall
    Dark Squall Medium Load Member
    557
    237
    Aug 11, 2013
    Grand Rapids, Michigan
    Have a factory spec Cobra 29
    New Wilson Trucker 2000 4'
    Factory wiring, recently cleaned and regrounded.
    Was having antenna warnings on CB with Fire Stick 2 recently and diagnosed a bad ground, loose mount bolt.
    Installed the new antenna, not receiving the warning.
    Taking this radio into the shop at Gary Flying J to Tweak and Peak radio and install new coax and mounts.
    I'm thinking about Co-phasing this set up.
    Any advice welcome in this.
    Thanks.
  3. jayjac1234512
    jayjac1234512 Bobtail Member
    7
    Feb 20, 2015
    Chicago, IL
    Dual antennas work, but try to keep about 9 feet of each other.
    (1/4 wavelength of 27mhz is about 9 feet)
    When running Duals - the antennas increase their gain forward and aft of the truck at the expense of some power to the sides... the signal to the side is about 1/2 an S unit lower....
    Dark Squall Thanks this.
  4. Dark Squall
    557
    237
    Aug 11, 2013
    I learned I can absolutely trust the shop in Gary at Flying J. They talked me out of it.
    They tuned my radio and checked wiring. All problems cleared up for 50.00
    Very happy. Buying a better radio in two weeks.
  5. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    A "better" radio? Maybe one with more doodads and features, but better? I seriously doubt that based on my experience. :D
    Big_m Thanks this.
