window ac
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Chicago123456, Jun 8, 2022.
  1. Chicago123456
    Chicago123456 Light Load Member
    67
    22
    Nov 27, 2020
    Ac does not work. nobody knows what’s wrong with it. I gave up. I will go with 3000 watts inverter connected to my batteries, 300amp fuse, 1/0 awg cable and 6000 BTU window AC unit installed at the back of my sleeper. will cut the hole and install it, secure it etc. I have 4 batteries. Do you think alternator will manage to load batteries so that the whole system works ? what can go wrong ? I plan to use that AC all the time ..when I drive and idle …
  3. kemosabi49
    10,961
    47,781
    Jan 13, 2013
    SW Arkansas
    If you are going to have the truck running the whole time, why can't you use the trucks A/C system? get the right person to get the rights parts in it.
  4. Munch75
    Munch75 Light Load Member
    202
    437
    Aug 29, 2021
    Not much can go wrong with AC. It's either a power problem, compression problem, or a refrigerant flow problem....sometimes an airflow problem.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,541
    6,619
    Aug 26, 2014
    That will never work. You could mount a generator.
  6. bumper Jack
    bumper Jack Heavy Load Member
    887
    4,411
    Dec 5, 2021
    What a rickety trash setup
  7. M22 rockcrusher
    M22 rockcrusher Road Train Member
    1,332
    4,138
    Nov 21, 2020
    If it is a flat top truck you could go with a rv ac unit
  8. Arctic_fox
    4,470
    25,141
    Sep 16, 2016
    That setup is likely to have every dot officer that sees it start to drool over doing inspections. Honestly if your AC is not working and you have checked everything on the electric and engine side then have them check the blower motors, blend doors and actuators. You can also have them test the actual switch. If its a newer rig the CCU can have a glitch and require it to be reset via said CCU. What your proposeing is pretty likely to cause a fire. Inverters dont like handleing huge loads like that constantly and is highly likely to damage your alt and/or batterys and maybe even wireing and computer
  9. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Can you translate this part? Especially the "nobody" part. I assume that means you took it to twelve independent shops, and three dealers.
  10. race27
    race27 Bobtail Member
    40
    31
    Jun 8, 2019
    window unit instalation will work fine if u pay attention to all the variables. first thing is u will need more than a 6000btu go with a 8000 minimum and mount it high as possible. most come with remotes but most important is to mount at a fairly steep angle. window units gain efficency when level so the drained condensation helps cool the coils. while on your 10 or 34 everything will be fine as long as u park with the right angle,nose up or level but not nose down. window units will work going down the road but when u go down a steep grade water may come bac into the wall. as far as power goes 2000 watts is more than enough. currently im running 10000btu and while it works on my 2000 watt inverter i run it off a generator. a gallon of gas all night verses diesel is a no brainer. an apu is more conservative than idling but not as cheap as a little gas. remember if u carry gas ur only allowed 8 gallons total. forget about a 300 watt fuse as all breaker are on the cord for the a/c, use it and u wont have to worry about sizing and the unit will always be protected.
    RomTon Thanks this.
  11. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    I think this was a Troll post , look at the OPs username lol
    God prefers Diesels Thanks this.
