Windshield constantly freezeing over.
Discussion in 'Ask An Owner Operator' started by feldsforever, Feb 13, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I guess its becoming a big enough problem to where I lost a nights drive last night.
    I figured this much out, either I don't know how to work the defroster of the windshield is bunk.
    Last night coming thru tennessee. I had I had to pull over and call it a day 45 mins into my shift. It was a extremely light drizzel and according to the dash 27 degrees frenhieght.
    As expected the roads where a bit glazed but enough traffic to keep them warm enough not to freeze over at this time. However the windshield keep freezing up. Literally a layer of ice on the windshield. I would pull over it would melt and the the wipers would push the water away. I start driving again and in five or 6 mins another layer of ice.
    It was bad enough I missed the rest area entrance. I know its something I'm doing as traffic has kept steady all night long and still is.
    Does the infamous freight liner leaky windshield have anything to do with this. Or is it operator error?
    On the heater panel I had it set to the windshield. Which then turned on the a.c so the windshield froze. I stopped and changed it to the normal vent and floor setting started moving again. And a nother layer of ice formed on the windshield. So I just called it and went to bed.
    If it is the leaky windshield issues can I run a bead of silicon around the edge or do I need to tell the boss I need a new windshield?
  3. Flat Earth Trucker
    4,297
    16,371
    Nov 19, 2018
    I have tiny window seal leak, too.
    As for your windshield freezing, I would tend blame the defroster.
    So let's secretly switch everyone's regular coffee brand to Folgers and listen in for comments.
  4. Ffx95
    Ffx95 Road Train Member
    1,370
    2,635
    May 18, 2017
    If you have an clutter on the dash that does impede the defroster’s ability to keep the windshield warm.
    Numb Thanks this.
  5. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    This happens to me when it’s around 0 and there is fog out.
    I usually just keep driving and look through the tiny 4”x4” peep hole where my defroster is blowing - everything else is solid ice .... :p
  6. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    Heat on high (like sweating hot), wipers going constantly, and when ice starts building up give good a sqirt of washer fluid... Also pull your visors down so they are about 4 inches from the windshield.
    nredfor88, Opendeckin, snowwy and 12 others Thank this.
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    I had this condition a few weeks ago. Sometimes Mother Nature dishes out more than the truck engineers can handle.
    I found the best solution in my instance was to slow down to about 45 mph, then the amount of mist hitting the windshield came down at a rate the defroster could handle.
    Yes, put controls on maximum heat, the defrost engages the ac compressor on purpose, it helps to dry out the air. If with heat on full it still feels like cool air, then the blend doors in the HVAC unit are malfunctioning.
  8. freebeertomorrow
    freebeertomorrow Heavy Load Member
    922
    1,745
    Mar 19, 2016
    Indiana
    this. x100
    feldsforever, Doealex and bzinger Thank this.
  9. rbrtwbstr
    rbrtwbstr Road Train Member
    3,399
    7,925
    Jul 11, 2012
    in the bush somewhere
    Western Star's are really bad for windows fogging up. You have the defrost on, the side windows fog up. Switch it over to vent air with the vents pointed at the side windows, and the windshield fogs up.
    The best solution I've found is keep the visor down like others said, and set the defrost to high, and crack the passenger side window a bit. Helps circulate the air a bit.
  10. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Thank you every one. I did not turn the fan on higher than 2 nor the heat over 60% ish. , I will try this next time.
    No dash clutter( its on the floor).
    Also will try the visor down.
    My speed was about 55 in a 70. If these of here hacks don't work I slower down a lil more.
    magoo68 and bzinger Thank this.
  11. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
    Fill your washer reservoir with RV antifreeze and use it liberally.
