windshield washer
Discussion in 'Volvo Forum' started by me myself and I, Mar 1, 2015.
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    My stopped working. Where is the pump located. How do i test it. Any suggestions how to get at it?
  3. Arkansas
    Arkansas Medium Load Member
    514
    668
    Dec 20, 2014
    LA- Lower Arkansas
    I'd check for a bad fuse first. If that wasn't it I'd look for a loose connection. I bet it's something simple.
  4. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    Are your hose lines hooked properly.. Are they clogged ?
    If none of the above ... follow your hose lines , you'll find the pump
  5. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    or they are just frozen
    baha Thanks this.
  6. LMB
    LMB "Olde Goat"
    1,692
    897
    Aug 12, 2007
    Rocky Point NC
    Mine is under the frame on drivers side, like the man said follow the hoses
  7. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    Pull the small hoses off your wipers, turn on the washer, see if you have pressure to the wiper. If not, check if the lines/nozzle is clogged or frozen. (Cranky has been there, but he's not saying. That's one thing the -25 wiper fluid is good for, not freezing quickly in the lines) If it isn't the wiring corroded, or lines frozen, get down there, ask someone to push the wash button and listen for the pump. Worst case? Pump can't be that expensive. You'll be able to get it going for sure.
  8. xsetra
    xsetra Road Train Member
    5,189
    7,137
    Aug 21, 2011
    I can't tell you where your pump is. Someone here probably can IF you put your truck information up here. My International had the pump inside frame rail under driver door. I think my Freightliner has it inline near firewall. I found them both by following water lines. Does the pump make any noise when trying to use or not. Good Luck.
  9. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    I thought my pump went out, but it was the plastic Inline Windshield Washer Filter that cracked and split, and when I pressed the Switch for Fluid it never made it to the nozzles on the Wiper Arms. I replaced the Filter and it works just like new. The Filter is located just a little downstream from the Reservoir, hidden between all the Air Lines. The Pump is located next to the bank of Truck Batteries on the Driver's side of your truck.
