Wiper motor problem, 2012 VNL 670
Discussion in 'Volvo Forum' started by gekko1323, Jul 29, 2025.
  1. gekko1323
    gekko1323 Road Train Member
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    So all of a sudden, my wipers stopped working. Luckily, I noticed it during pre-trip. I checked the fuse first, and sure enough, it was blown. So I put in another fuse and it blew immediately. The fuse was a 25 amp, so I then put in a 35 amp to see if that would solve the problem. The moment I touched the terminals in the slot, the fuse blew pretty violently! Half of the prong on the fuse was melted!
    So I went under the hood and disconnected the plug from the wiper motor. I then put in a new fuse and started the truck. This time, the fuse didn't blow. So do I have a bad motor?
    Thanks for any help.
  3. 86scotty
    86scotty Road Train Member
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    Yes, known Volvo problem. Replace wiper motor.
    Often they stop working mid-stroke. They kind of freeze for a second, then start again. Mine has done this a few times and fixed itself.
    I don't trust it anymore but I'm lazy. Just replace the motor.
    Siinman, gekko1323 and Grumppy Thank this.
  4. Grumppy
    3,233
    11,401
    Dec 11, 2010
    West Monroe, La
    Mine went out last week. 2022 Volvo. It was raining.. wipers going, then like Scotty said, it stopped mid stroke. They were sticking straight up.
    Replaced the motor and all is good. Shop told me its a common problem... Just like Scotty said.
    The little shop we use keeps them in stock.
    Siinman and gekko1323 Thank this.
  5. gekko1323
    1,658
    2,766
    Jul 14, 2018
    Henderson, NV
    Just curious...how does a bad motor blow the fuse? If the motor doesn't work, how does it affect the fuse?
  6. JB7
    JB7 Road Train Member
    1,006
    1,781
    Dec 13, 2022
    Laurel, MD
    Bad motor does not necessarily mean a dead motor. Bad meaning something wrong in it electrically or otherwise that causes enough increase in the amperage that exceeds the fuse limit. When that happens the fuse blows.
    What the others describe sounds different from your problem though. They describe the motor freezing momentarily or stop working but they don't mention anything about a blown fuse.
    gekko1323 and Siinman Thank this.
  7. 86scotty
    4,699
    12,896
    Aug 27, 2017
    Appalachia
    True, I just know the motors go bad and it usually starts with freezing. I can't really speak to the fuse issue. I'd test ground and voltage at the plug from wiring harness to wiper motor before I plugged a new motor into it.
    gekko1323, JB7 and Siinman Thank this.
  8. Siinman
    Siinman Road Train Member
    5,513
    14,173
    Mar 5, 2017
    Kansas City, MO.
    Had one go out on this truck. Bad motors are an issue with the newer models and was a recall. Not sure you have the same issue, might be a wire that is grounding out. Check all wiring and if nothing I would just replace the motor as that most likely is the problem.
    gekko1323 and JB7 Thank this.
