wiper problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by markk, Jul 5, 2023.
  1. markk
    markk Medium Load Member
    566
    197
    Nov 14, 2011
    17 Pete 579. Wipers lost all but low speed and it only works on 1 notch below high speed.
    Then it started stopping in different positions when on intermittent .
    Is it the motor or the control on steering wheel ?
    I read it was the control.
    D.Tibbitt Thanks this.
  3. Concorde
    Concorde Road Train Member
    5,456
    19,202
    Jun 29, 2016
    West Melbourne Florida
    Probably just the stalk. My 21 and 23 389 had/has issues with the wipers cutting out and stopping.
    Just absolute garbage and every time I get one replaced the problem comes back a month or two later. On intermittent sometimes it won’t work or just stops. On low speed it’ll be fine for a few minutes and then just stop..
    Get a new one installed but don’t expect it to last very long..yours sounds like it’s completely worn out.
    D.Tibbitt, markk and Siinman Thank this.
  4. JB7
    JB7 Road Train Member
    1,001
    1,767
    Dec 13, 2022
    Laurel, MD
    Probably correct. But be aware that the wiper control runs through the Chassis Node. See Pin C17 on page 2 of the attachment. Hard to believe they make sheet this complicated. A lot of lighting problems end up being the node.
  5. Concorde
    5,456
    19,202
    Jun 29, 2016
    Thanks, good information..
    Siinman Thanks this.
  6. markk
    566
    197
    Nov 14, 2011
    Is this the part on the steering column or something else ?
  7. Saladtrucker
    Saladtrucker Bobtail Member
    Jun 27, 2023
    It's the stalk. Paccar has a recall on them which just gets a new one for free once. The problem will return. They didn't actually fix the issue, they just replace the bad one with another eventual bad one.
  8. D.Tibbitt
    156,672
    Had that problem with my 567 pete now I've got it on the t680 .. brand new truck... turn signal is intermittant as well... Paccar makes alot of junk now
