Witch oil ??
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by johnnyboyloco2500, Jul 10, 2019.
  1. johnnyboyloco2500
    johnnyboyloco2500 Light Load Member
    67
    12
    Dec 7, 2015
    Lebanon,Oregon
    Got cummis isx 2250 2012 in my pete.
    Been running delco full synthetic
    5w30.
    Have 731574 miles
    Oil presure drop from 38-40
    To 30-35. 1000 miles from oil change
    Any suggestions
  3. Goodysnap
    Goodysnap Road Train Member
    3,769
    9,190
    Jul 12, 2017
    Your still well within acceptable pressure range. Is this Idle or cruising pressure? Maybe filter starting to get plugged from soot is not at all uncommon especially with aftermarket filters. Changing the oil might come back up. Get pressure gauges hooked up and measure drop across the filter if your unsure.
    What oil are you running? Delco or Dello?
    Rideandrepair and QUALITYTRUCK Thank this.
  4. Confused
    Confused Light Load Member
    224
    270
    Sep 22, 2009
    somewhere else
    Is " Witch oil " , some sort of concoction brewed up in a cauldron ?
  5. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Maybe it's a new oil on the market.
    Rideandrepair and D.Tibbitt Thank this.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Sounds like a new variation of snake oil.
    mhyn, MartinFromBC, D.Tibbitt and 3 others Thank this.
  7. EnzoEST80s
    EnzoEST80s Bobtail Member
    May 31, 2019
    motorkote has some new oil out too js lol
    D.Tibbitt Thanks this.
  8. Humblepie
    Humblepie Pontificator
    5,077
    80,318
    Dec 25, 2018
    I’d go with canola or corn. The farmers need our help!! Willie Nelson said so.
  9. lwlevens
    623
    427
    Feb 9, 2018
    Used fry oil is good also smell like a big french fry going down the road.
