Worn air line
Discussion in 'Questions From New Drivers' started by Mototom, Sep 24, 2022.
  1. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    So just had my belly spring break and am now stuck at a hole in the wall spot.
    I only got here by spite and two rolls of electrical tape
    What’s the dot approved method of fixing this? Compression fitting? (For a one inch line?)
    I also recently switched companies so this is extra fun dealing with their road service department.
    (spring broke air line hit the ground big ### hole in air line)
  3. AModelCat
    164,627
    What's a belly spring?
    Synflex, rubber or braided air line?
  4. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    7/8 piece of pipe cut 4 inches and 4 hose clamps to limp to greener pastures.
    Good Luck
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    He is probably talking about the air lines in front of a sliding tandum trailer suspension. I have never heard of it referred to that way as well.
    AModelCat Thanks this.
  6. kemosabi49
    10,977
    47,914
    Jan 13, 2013
    SW Arkansas
    I have used this on an air line and it didn't leak. Got me to a shop.
  7. Mototom
    1,388
    2,703
    May 7, 2019
    Really? That’s like THE term used around here…? What do you guys refer to it as lol.
    also yes thats what I’m referring to.
  8. Mototom
    1,388
    2,703
    May 7, 2019
    Rubber line
  9. Mototom
    1,388
    2,703
    May 7, 2019
    Yeah I thought of that but I actually found a barb fitting at the local tractor supply.
    I don’t think it’s dot legal tho lol. There’s got to be something out there tho?
    Hydrualic line style compression fitting maybe??
  10. xsetra
    xsetra Road Train Member
    5,196
    7,146
    Aug 21, 2011
    BoxCarKidd Thanks this.
  11. Ridgeline
    22,720
    123,272
    If you want to be legal on a splice, get a DOT fitting from someplace like NAPA truck parts dealer or a Parker Hannifin hydraulic store, they both have them.
    Mototom Thanks this.
