Would this work, or not?
Discussion in 'Ask An Owner Operator' started by Frontman, Nov 13, 2020.
  1. Frontman
    Frontman Light Load Member
    166
    151
    Apr 4, 2012
    I am looking to drive 10.5 hours to receiver, but I can not drop trailer till the next morning.
    So, I would have 9 hours in sleeper (not 10) before I had to move trailer 1/2 mile.
    Can I use the 8/2 split, or in my case, 9/1?
    After dropping trailer go back in sleeper outside of receiver for 1 hour to get my 14 back?
    Or would it have to be 2 hours back in sleeper?
    I'm using the KT ELD this trip .. I don't usually use this thing but this week I'll be outside my 100 mile radius.
  3. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Nope. It requires a minimum of 8 in the sleeper and 2 either off or sleeper. You can do 9 in the sleeper, but you still need the 2 to do a proper split.
    Frontman Thanks this.
  4. Frontman
    166
    151
    Apr 4, 2012
  5. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Pc
    ready2truck and blacklabel Thank this.
  6. Frontman
    166
    151
    Apr 4, 2012
    If I questioned about that, I’d have to explain why it take me 20 minutes to move 1/2 mile.
    I’m not that good of a liar.
    alds Thanks this.
  7. Spyro2112
    623
    433
    Mar 17, 2018
    Sign out put mechanic road test
    alds and blacklabel Thank this.
  8. Frontman
    166
    151
    Apr 4, 2012
    @ZVar
    So, after taking the 9 hours in sleeper, on duty for say 30 minutes, back to sleeper in my case for the required 2 hours. After the 2 hours in sleeper, do I get full 14/11 back? Paragraph below says NO, is that right?
    After you take your second split of the pair, whether it’s the shorter or longer of the two splits, do you start your hours fresh?
    No. To reset your hours, you need to go off-duty for a full 10-hour break. If you use the split-sleeper options, when you go back on-duty after any off-duty split period, your remaining time available is calculated by subtracting from your 14-hour clock and your 11-hour clock the time you were on-duty between the two breaks.
    “As the rule states, you start your count from the end of the first break, [minus] whatever you used in between,” said Hansen. “If you were on-duty for five hours between the breaks, then you have nine hours left on your 14 and six hours driving time, if you drove for those five hours. It’s whatever’s left after you subtract out what you did between the two breaks.”
  9. ready2truck
    ready2truck Medium Load Member
    301
    352
    Oct 27, 2020
    just break the rules.
  10. Idahojoel
    Idahojoel Light Load Member
    63
    48
    Jan 17, 2018
    Phoenix Arizona
    you are aware it’s 150 air miles now not 100?
  11. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    OP said he was driving 10.5 hours to the receiver
