X15 cam failure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by calvinbabb, Jun 3, 2023.
  1. calvinbabb
    calvinbabb Light Load Member
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    I have a Cummins x15 economy. Two cam lobes are bad and of course, 2 rocker arms. Manufacturing date on engine is 04/2017. Engine has 645xxx miles. I’ve owned for 100k of those. Kenworth is stating engine rebuild, but for a cam failure? The cam isn’t that bad so can’t see rebuilding the engine. In a mechanics point of view, what else should be changed to run this engine? Can’t help but think the dealer is trying the leach me.
    D.Tibbitt Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    That’s because you’ll be really mad when it starts pushing coolant due to a dropped liner 2 months after you put a cam in it.
    Are the front a rear housings leaking yet?
    You already know it hasn’t had regular maintenance with the worn camshaft.
    LoneRanger, lester, D.Tibbitt and 3 others Thank this.
  4. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    id just do the cam and ride
    AModelCat and D.Tibbitt Thank this.
  5. D.Tibbitt
    157,089
    What were your symptoms that led to finding a bad cam?
  6. Diesel Dave
    9,653
    32,680
    Jan 20, 2010
    Hesperia, Ca.
    I usually blame those failures due to lack of valve adjustments. I have a ISX 15 and run through the adjustments yearly regardless of mileage. Just my .02
    D.Tibbitt and Dave_in_AZ Thank this.
  7. Dave_in_AZ
    424,098
    Slow week at that stealership.
    NWAF and Diesel Dave Thank this.
  8. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Where did all this cam material go? What did it pass through on it’s way?
    Oxbow Thanks this.
  9. calvinbabb
    66
    41
    Apr 28, 2016
    Trenton, Fl.
  10. calvinbabb
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    I’ve only had it a year and about 10 months on the adjustment
    Dave_in_AZ and Diesel Dave Thank this.
  11. calvinbabb
    66
    41
    Apr 28, 2016
    Trenton, Fl.
    Started hearing a rocker arm tick. Still ran fine and was still averaging 8.4 mpg. But I did run it about 2400 miles like that.
    Dave_in_AZ and D.Tibbitt Thank this.
