X15 Top End Set
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by north60, Feb 22, 2021.
  1. north60
    north60 Bobtail Member
    43
    25
    Jun 13, 2019
    Doing a top end set on a X15 Performance Series. After setting the valves you are supposed to check the running clearance on the jake brake rockers. What position is this checked in, anytime the exhaust valve is closed?
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Correct. Set brake clearance after adjusting exhaust valve clearance on the same cylinder.
    Spec is 7mm. Allen wrench works good substitute for buying the expensive Hockey stick from Cummins.
    pushbroom and BoxCarKidd Thank this.
  4. north60
    43
    25
    Jun 13, 2019
    I set the brake clearance already. My question is with the "Running Clearance" .025"-.110"
  5. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    All adjustments are made with valves closed.
  6. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    Check the running clearance after you make the adjustment. Let the engine brake rocker sit in its neutral or detent position. .025-.110 between the brake rocker & valve. I use a .025 & a stack up of guages to make up the .110 .
    north60 Thanks this.
