Yeti cooler vs 12v
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by ethos, May 31, 2017.
  1. ethos
    ethos Road Train Member
    4,252
    13,464
    Mar 3, 2013
    Fort Worth
    So as some of you know I recently switched companies. I went from years in Cascadia to a Mack. Now, that took some changes and the one thing I quickly realized was that my cooler set up wasn't going to work. The Mack is just not as big. For years I have run two coolers. A Koolatron P20 and a P25. The 20 is the skinny white one and the 25 is the boxier one with the fans on top. They sell both at truckstops so I know all of you guys have seen them. I keep the 20 up front so I can access drinks or cold snacks while driving. The 25 worked as more of a storage.
    Well the room limitations meant I had to make some changes, space was at a premium. I decided to drop the 25 and replace it with a Yeti hopper. The hopper is a soft sided cooler. I have the bigger one, can't remember the model number... 30 something I think.
    The Yeti, like all of their products is built like a tank, excellent quality. It is a large capacity cooler that doesn't take up too much room. But I know what you really want to know, how long does it hold ice? Well, the max for me has been 3 days. That is sitting in my sleeper with the A/C on virtually all the time. Now the water will still be cold after 3 days but that only last a short while.
    So how's life on the road with it? Not too well I'm afraid. First off, like all ice coolers you have to add ice. The soft sided coolers do not have a drain plug. This means that I have to manhandle the thing from the sleeper to the outside. Unzip it a bit and pour the water out while keeping all of my food and remaining ice in. Then I have to add the ice which is tough because the cooler doesn't open very wide. Now, since this is going in my sleeper it won't touch the ground so I do this all while supporting it. It has a nice shoulder strap and that helps.
    Also, adding ice means I have to fish around in it to find things. Once the ice starts to melt it is easier to find stuff but it makes everything wet...obviously. This means that any paper based packaging becomes suspect. And that 3 days is the MAX that I've had. Usually it's two days for a 10 pound bag. Adding more ice means longer intervals but adds weight, reduces capacity and makes it very difficult to find stuff.
    I own many Yeti coolers and they are amazing, the hard ones anyway. The soft sided cooler is just not working well for me. I think I am going to buy another 25 and set that up in the sleeper. It's just that Yeti's are not cheap and I feel like I need to make this work because I have no other use for it. Anyway, that is my, rather unnecessarily long review.
    Bean Jr. and tlalokay Thank this.
  3. ExOTR
    ExOTR Windshield Chipper Extraordinaire
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Why lug the big cooler to drain it? Buy 7-10 feet of thin hose and gravity bleed it.
    rabbiporkchop, tscottme and ethos Thank this.
  4. ExOTR
    1,706
    1,893
    Jan 23, 2013
    Fort Worth, Tx
    Benefit of the Yeti is also decent resale value, esp if you still have the receipt showing it's new...
    mnmike and ethos Thank this.
  5. ethos
    4,252
    13,464
    Mar 3, 2013
    Fort Worth
    That is a good idea, I'll try it.
  6. tlalokay
    tlalokay Medium Load Member
    473
    773
    Jun 3, 2014
    El Paso, TX
    I recently went the way of the cheaper Ozark Trail knock-off of the soft-sided Yeti cooler.
    Not bad. I hear you with the hassle of draining the water every two days. But it kept my cream cheese, milk, cheese dip and salad dressing cool enough. Also, I was able to get away with adding 2 large styros of free ice from the fountain each day, instead of buying ice.
    That was during a route from Buffalo to Salt Lake, then down to Phoenix. Not sure how it will do during the hotter summer months.
    rabbiporkchop and ethos Thank this.
  7. HoserSmurf
    HoserSmurf Light Load Member
    74
    45
    May 17, 2017
    YETI does sell a drain plug hose connection that fits a standard hose for $12.99. Not sure if that'll work? Btw, luv my Roadie Tundra compact and adequate for the road. :cool:
  8. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Freeze some water bottles instead of using ice if you have a freezer in your truck fridge.... Rotate bottles daily
    Friend Thanks this.
  9. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,141
    Jan 30, 2011
    Welcome to the club of trying expensive things that don't work. Maybe sell it on eBay or craigslist.
    Since you're not afraid to spend Yeti money, try a Dometic cooler. Look at the CoolFreeze line. They have a real compressor system, and will keep ice cream if you want it that cold. I have two of an earlier model of this 18 qt cooler, that are 2 and 3 yrs old and still work great. I don't need anything bigger, as I usually only stay out 4-5 days max. It's big enough for cold cuts, yogurt, sour cream, fresh fruit, and a few cold drinks. If you make more than sandwiches and snacks, you might consider a bigger one. Keep in mind they are heavier, so look at the weight when you read the links I posted.
    I'd avoid their Tropicool models. They are cheaper, but functionally similar to the Coolatron at a truck stop, albeit better constructed.
  10. ethos
    4,252
    13,464
    Mar 3, 2013
    Fort Worth
    I had never heard of those. You have peeked my interest.
  11. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    $977 @ walmart
