14.0 detroit 515 help, 4.1mpg is killing me
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jayz8886, Nov 2, 2009.
  1. jayz8886
    jayz8886 Bobtail Member
    Thanks Received:
    Aug 14, 2009
    oklahoma
    The truck is a 05' Xl Freightliner, specs are 480k miles, 3.55, 13 speed .78 over with 22.5 rubber, an a 14.0 515 detroit.
    My driver is complaining of low power and on the best mpg average its getting 4.3. I have it governed to 68 and it hauls a 48' flat.
    I have had it back to the Freightliner shop 2 times and they say that all is good that it driver and not the truck. But he came from my 03' Xl with a 500 detroit set to the 68 mph getting 6 mpg.
    I'm at the point where I will do better parking the truck than dealing with the bad mpg.
    Is anybody else having these issues or have ideas on where to look?
  2. Stroked F550
    Stroked F550 Medium Load Member
    324
    Thanks Received:
    39
    Jan 23, 2008
    somewhere
    have you checked for boost leaks?
  3. Jim Bob
    Jim Bob Light Load Member
    183
    Thanks Received:
    49
    Aug 2, 2009
    Portland, Or
    Put it on a dyno and go from there. $150 is cheaper than wasting it in fuel.
  4. Tank33
    Tank33 Medium Load Member
    346
    Thanks Received:
    104
    Jan 10, 2009
    British Columbia
    I posted in a similar thread of mine that I have a friend with a Classic and a 14.0L Detroit, his fuel mileage is horrid. He is running 3:70 or 3:90 rear ends, cant remember, 13 speed, 22.5 rubber. He drives between 100 and 110 KM/H, pulls heavy one way, and very light the other, and his fuel mileage is horrid, usually in the 4's.
    Freightliner says it is working right.
    My suggestion is, take it to Detroit, not Freightliner. Freightliner mechanics focus on Freightliner trucks. Detroit mechanics specialize in Detroit engines, take it to them, let them update the software and check the turbo, and check the air-to-air. Pressure test for leaks.
  5. jayz8886
    Thanks Received:
    Aug 14, 2009
    oklahoma
    Yes is shows to be fine on a leak down test. I have went over all the common stuff on it that I am use to doing on Detroit's (filters,leak down,boost).
    This is the first egr engine I have dealt with and just not sure where to go. It shows to be getting 6.5 on the comp but the real numbers only show around 4.1-4.3.
    I don't have the time but I may have to take a few runs in the truck to see how it actually runs. The only seat time I have in it is from bob tailing home from the dealership.
  6. Jim Bob
    183
    Thanks Received:
    49
    Aug 2, 2009
    Portland, Or
    Is somebody stealing your fuel outta the tank? It happens. That or you might have a diesel leak.
  7. jayz8886
    Thanks Received:
    Aug 14, 2009
    oklahoma
    Its possible, but have no evidence to say its leaking or bein stolen.
    I will see about getting it into detroit in the morning to have them look it over.
    Thanks for the help.
  8. PaulE
    PaulE Medium Load Member
    413
    Thanks Received:
    136
    Jan 15, 2009
    Verona Wi
    Had a friend spend alot of money and time chasing same problem with an MBE. turned out truck was fine, odometer was running way short. changed tire size when he bought the truck and odometer had not been programmed right.
    Jim Bob and Beechvtail Thank this.
  9. 550hpW900L
    550hpW900L Road Train Member
    1,872
    Thanks Received:
    1,065
    Jan 29, 2008
    norcal
    Sounds like your driver is selling fuel.
    Beechvtail Thanks this.
  10. stranger
    stranger Road Train Member
    3,437
    Thanks Received:
    4,336
    Oct 10, 2006
    NC
    Was going to say that myself. I've had drivers sell some of mine before.
    According to Detroit specs, a 3.36 rear would be better for fuel mileage since you have a .78 OD and LP 22.5s
  • Draft saved Draft deleted
