2013 international pro star exaust fumes in cab
Discussion in 'International Forum' started by pamtrucker2013, Oct 20, 2013.
  1. pamtrucker2013
    pamtrucker2013 Bobtail Member
    4
    Thanks Received:
    Oct 20, 2013
    I have been getting raw exaust fumes in my cab when driving. Also when I am sitting idle .
    This truck has been to a dealer for this problem,but the problem still exsist.
    From time to time when I am driving there is a rush of fumes into the cab.
    When I am idling I get them when I turn on the front hvac system through the vents.
    Not so much on the sleeper hvac.
    Any suggestion's on what's causing this , any known problems with this model?
  2. Richter
    Richter Road Train Member
    4,091
    Thanks Received:
    1,640
    Feb 13, 2012
    Philadelphia Pa
    first off, GET A CARBON MONOXIDE ALARM ASAP. you want to know it it happens while your asleep. That being said, do you have a grass burner or stacks. Check near the intake for your air system and look for any leaks. im a fl guy, but my truck pulls air form in engine compartment. If there was a majot leek int here it would flow right into cab
    pamtrucker2013, Marky84 and Reycer Thank this.
  3. luvtotruck
    luvtotruck Road Train Member
    1,979
    Thanks Received:
    1,150
    Jul 30, 2013
    Phoenix Arizona
    What about running the recirculate to where only the cab air gets cooled off and then the fumes would be less or none.
    pamtrucker2013 Thanks this.
  4. pamtrucker2013
    4
    Thanks Received:
    Oct 20, 2013
    this truck has no stack . the muffler is under the sleeper . the smells are mainly coming through when hvac is running . As for the detector , I work for pam . i can't afford a detector .
    paul_4lp Thanks this.
  5. pamtrucker2013
    4
    Thanks Received:
    Oct 20, 2013
    I think the only way to do that is to keep the switch on ac . when you change it to fan to use the heater im told by another trucker i spoke to today that it opens an fresh air intake in the engine compartment , which would explain the fumes im getting when using the heater .
  6. Heavyd
    Heavyd Road Train Member
    4,262
    Thanks Received:
    1,896
    Feb 4, 2009
    The exhaust bellows pipes between the EGR valve and exhaust manifold tend to leak. The exhaust manifold itself likes to leak at #5 and #6 exhaust port, or the slip connection between the center and rear manifold sections. The braided flex section can also leak in the main exhaust pipe right after the engine. Leaks will produce carbon staining in the area. Try a different dealer.
  7. EZ Money
    EZ Money Road Train Member
    2,814
    Thanks Received:
    1,615
    Oct 27, 2010
    Charlotte,NC
    The braided flex pipe behind the turbo just as it goes under the passenger side of the cab leaked twice on my ProStar...
    Like HeavyD stated look for dark stains in that area.
    That area is directly below the fresh air intake of the front AC system.
  8. Heavyd
    4,262
    Thanks Received:
    1,896
    Feb 4, 2009
    During a regen the smoke will really come out of that section!
  9. EZ Money
    2,814
    Thanks Received:
    1,615
    Oct 27, 2010
    Charlotte,NC
    Sure will and if you have a leak it will stink you out of the cab!
    I got buy tightening the clamps on the flex pipe the first time then had it replaced about a year later.
    Running the AC on recirculate helps but any exhaust leak is not a good thing.
  10. Richter
    4,091
    Thanks Received:
    1,640
    Feb 13, 2012
    Philadelphia Pa
    they cost only 30 buck...is your life not worth 30 bucks?
  • Draft saved Draft deleted
