2017 Western Star what diagnostic port?
Discussion in 'Western Star Forum' started by GPS Guy, May 19, 2016.
  1. GPS Guy
    GPS Guy Bobtail Member
    7
    I am trying to find out what diagnostic port the new western stars are coming with. 9 pin green or 16 pin OBD style.
  3. Animosus
    Animosus Medium Load Member
    656
    2,482
    Dec 7, 2015
    SE Wyoming
    9 pin green.
    GPS Guy Thanks this.
  4. GPS Guy
    7
    Thank you. Square or D flange. Ill Post Pics
    Square 9pin 500k picture below.
    D-Flange version below. the right plug not left. (could not find a picture of this in green 500K that had the right angle of view)
    Reason for edit: updated with images.
  5. GPS Guy
    7
    Update. found a picture of the 500K D version but it not hosted online. it is my pic.
  6. Animosus
    656
    2,482
    Dec 7, 2015
    SE Wyoming
    Never paid attention. I'll go check on one of our new trucks on the lot tomorrow.
  7. GPS Guy
    7
  8. Ridgeline
    20,734
    101,040
    It is not an odb connection or protocol, it is a can protocol so your car software and adaptor will not work.
  9. GPS Guy
    7
    1. OBD stands for On Board Diagnostics, so by definition it IS a OBD connection.
    2. The protocol we are using was never discussed on this thread so you do not have enough information to tell me what I am doing is not going to work.
    3. In post #2 in this thread we established that this port is a green 9pin not a 16pin typical OBDII style end like what is used in 2014 and up Mack and Volvo trucks. So why are you RIDGELINE coming in at post #7 and thinking we are still trying to figure this out?
    4. At this point we are trying to determine if the 9pin green 500K connection is Jam nut mounted to the panel, or 4 screw mounted to a bracket.
    Reason for edit: Removed insult
  10. GPS Guy
    7
    Bump, Anyone with a 2017 western star that can confirm if the green 9pin port above your left foot area is jam nut mounted or 4 screw mounted? Pictures of each above.
  11. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,113
    May 19, 2011
    I have a 16 and it's jam nut mounted.
