387 Pete Doors Sagging
Discussion in 'Peterbilt Forum' started by terrylamar, Jan 20, 2013.
  1. terrylamar
    terrylamar Road Train Member
    1,023
    Thanks Received:
    348
    Oct 8, 2006
    Austin, TX
    My doors on my '05 387 Pete are out of adjustment. This is causing wear where the fiberglass is rubbing, excessive wind noise and binding if I let the seat belt get caught between the door and frame. I am wondering if the doors can be adjusted back into proper position or is the problem caused by the fiberglass attachment points wearing out?
  2. Don2WS
    Don2WS Medium Load Member
    306
    Thanks Received:
    24
    Feb 26, 2010
    Sturtevant WI
    this has happened to our t2000s the fiberglass skin is glued to the door frame and when the door was opened the skin would pop and the bottom hinges would hang. i took the door off and took of the spacer plate and replaced it with a sheet of steel the same thickness and bent that so that it could go around the corner of the door and reinforce the hinge area
    bstromback2002 and terrylamar Thank this.
  • Draft saved Draft deleted
