Add on DPF
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sshewins, Apr 16, 2015.
  1. sshewins
    sshewins Road Train Member
    1,631
    4,730
    Aug 21, 2011
    Hi there. Wondering if anyone knows first hand anything about those aftermarket add on dpf's? I know, I know, stay out of CA. We are supposed to be picking up a bit of work going that way and it really doesn't pay that bad. Trying to look 'big picture' to see if it's worth doing a retro kit, or just break down and buy a new truck. Trying to get pros and cons from guys that have actually done it, or know someone firsthand that has.
    Not sure exactly where I stand on this issue, but trying to make an informed, intelligent decision, without emotional drama.
    Thanks
  3. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
    DPF add on's are not permitted any more. Just buy a newer truck.
  4. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    OP: I haven't seen any good info on this site about retrofits. I've talked to some local fleets who have had decent results, & I've talked to some that had nothing but problems and wound up selling the truck within 6 months of retrofitting...
    Example decent result: USF Redaway on their linehaul trucks (very little idling, mostly highway)
    Example terrible results: Port drayage trucks (very little freeway, lots of stop & go, lots of idling)
    Wrong. The rules are here: http://www.arb.ca.gov/msprog/truckstop/truckstop.htm
    rachi and icsheeple Thank this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    I wouldn't add one on ... I'd keep the older truck running outside of Cali ... If you need to go there with any regularity I'd buy something new ... Retrofitting an engine that was never designed to run with a dpf is a good way to kill it ... Remember the first round of dpf trucks? They were designed to work with one and they all failed miserably ... At least with a new truck you have warranty and most of them seem to run ok, most of the time ...
    rachi Thanks this.
  6. sshewins
    1,631
    4,730
    Aug 21, 2011
    I was kinda thinking that since there had been a bit of time since the original oem and these retro kits, that perhaps they got it closer to being right (as right as right can be). I was also thinking that since the kit is (I'm guessing) more or less a bolt on and stand alone, it really shouldn't be severely detrimental to the engine.
  7. snowwy
    snowwy Road Train Member
    20,536
    13,272
    Jul 6, 2009
    on the radio, it was a disaster at first. but more and more people are starting to claim good results and mileage.
    it's a crapshoot still though,
  8. Diesel Dave
    8,651
    24,426
    Jan 20, 2010
    Hesperia, Ca.
    I have just done a retrofit through a reliable CARB approved installer. It set me back quite I bit. It's all about the install. If install correctly there will be no issues long as you follow the maintenance. I have noticed absolutely NO difference in performance except that my truck is quietier. I went from straight stacks to DPF. Trucks sounds like a new truck. I missed the sound of the straight pipes already but it is what it is. I have seen several retrofit installer and to my disapointment felt sorry for the owners. They hack the utility box on the passenger side step and the fliter stands out like a sore thump. My install in the other hand, the utility box was completely remove and a new fabricated one that look identical(a little bigger) was reinstall with the filter inside and the inlet and outlet facing under the carriage. Now to the OP, is it worth it you say ?, To me it was was either a 2010 truck or newer or the filter, To start of with, I see NEW trucks all day long broke down on the side of the rode cuz of the emissions stuff in them, that cost more money due to down time, tow truck, and shop repair plus your new truck payment, due the math. I am fully satisfy that i went with the retrofit and that I am not stuck with the newer truck headaches that my buddies have ran into. All have said they wish that they would of done the retrofit.
    rachi, areelius, mp4694330 and 2 others Thank this.
  9. allisonisatranny
    188
    131
    Oct 6, 2014
    Well, they changed it again. Previously, if you didn't have a DPF retrofitted by a certain date, you could not claim an exemption and register your vehicle to run in California. What a headache.
  10. sshewins
    1,631
    4,730
    Aug 21, 2011
    Diesel Dave, has your mileage suffered any?
    I can't verify this information that I'm about to say. A good friend of mine was loading at a gas rack a couple of days ago in IN.He was talking to another driver about his (other driver) Fitzgerald glider. The other guy said that next year (?) Fitzgerald (and any glider builder) was going to be required to install a dpf on the new glider. Again, I can neither confirm nor deny this. I'm gonna call them to confirm this.
    Just hung up with Mike at Fitzgerald. No truth to the add a dpf filter mandate. That's a good thing.
    According to an article in 10-4 magazine, by 2023, all trucks must have a 2010 or newer engine. That's only 8 years away. And I'm not sure if it's for CA trucks only. CA sure has rotating laws when it comes to truck emissions, don't it?
