Battery wiring KW W900
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Jul 28, 2010.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,960
    Thanks Received:
    886
    Oct 1, 2009
    Midwest
    I am replacing the (4) batteries in my KW this weekend.
    I want to totally remove the stuff and clean it and replace parts but was wondering how these are hooked up?
    The dealer told me either (2) for the starter in parallel and (2) for the cab or all (4) are in parallel. That wasnt much help.
    Here are what they look like now:
  2. kwswan
    kwswan Heavy Load Member
    849
    Thanks Received:
    582
    Jul 26, 2009
    mcminnville,tn.
    cut the wire ties holding everything together.
    leave the cables hooked up,but pull them apart to where you can see which way they are hooked up.
    get you a pen & pad & draw a diagram of how they are hooked up.
    take apart,clean & reassemble according to diagram.
  3. black_dog106
    black_dog106 Road Train Member
    1,405
    Thanks Received:
    472
    Mar 29, 2009
    Shelburne Falls, MA
    :biggrin_25525:.... now that sounds easy...
  4. Hanadarko
    2,960
    Thanks Received:
    886
    Oct 1, 2009
    Midwest
    Thats sorta what I was thinking, but I am still curious as to how they are hooked up. I need schematics on this truck!!
    :biggrin_25525:
  5. belltransit
    belltransit Light Load Member
    271
    Thanks Received:
    25
    Jun 28, 2010
    oak grove, mo
    or you can do what you just did and take a pic of them and then look at the pic to make sure you have everything back right.
  6. Hanadarko
    2,960
    Thanks Received:
    886
    Oct 1, 2009
    Midwest
    I removed some of the #### that the prior owner ran right to the batteries but there is one black wire (with fuse) that has KW sticker labels on it. Not sure what thats for..
  7. country29
    country29 Medium Load Member
    513
    Thanks Received:
    139
    Feb 27, 2010
    well make sure it gets hooked back up! looks like there are 4 main power and ground cables, so that tells me 2 are for starter, and 2 are for the truck. just from what I can see in the pics.
  8. Hanadarko
    2,960
    Thanks Received:
    886
    Oct 1, 2009
    Midwest
    According to KW, the 2 main power leads go to the starter. I guess I will find out when I start snippin some of these wire ties.....Its one of the projects for this weekend. it has given me some issues starting too, only once in awhile so I am replacing the starter solenoid in the battery box area as well ($50).
    I am not sure how to clean these battery connectors though. They are all rubberized but for the very center that slides onto the threaded stud on the battery....
  9. belltransit
    271
    Thanks Received:
    25
    Jun 28, 2010
    oak grove, mo
    you can spray the ends with some kind of cleaner and then scrape them as best as possible. ive used a knife or even a screwdriver.
  10. oneshot
    oneshot Medium Load Member
    627
    Thanks Received:
    240
    Feb 28, 2009
    mississippi
    I think if that fuse blows,the truck want crank.Maybe ECM fuse.Mine is an 06 with 2 fuses an I think it's for the ECM.
    Hanadarko Thanks this.
  • Draft saved Draft deleted
