Cummins engine not enough boost
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Richard52, Feb 18, 2014.
  1. Richard52
    Richard52 Bobtail Member
    Thanks Received:
    Feb 18, 2014
    I have an ISX 550 Cummins engine. It is not getting enough boost. Only about 12 pounds of pressure. I found a crack in the air to air charger and replaced it. Still not getting enough. Any ideas?
  2. bgxpress2006
    bgxpress2006 Light Load Member
    244
    Thanks Received:
    67
    May 25, 2013
    Montreal, Quebec
    did you check your rubber boots going to the air to air
  3. manasteel
    manasteel Light Load Member
    124
    Thanks Received:
    30
    Sep 10, 2012
    check the hose at the air compressor intake. it will rip on the back side
  4. Rig Wrench
    Rig Wrench Medium Load Member
    393
    Thanks Received:
    58
    Dec 24, 2010
    northeast
    Check the map sensor, prolly packed full of carbon. Check the exhaust back pressure sensor on the thermostat housing too. Also may need to run a turbo test through insite. If the vanes are sticking it may cause this issue too
  • Draft saved Draft deleted
