cummins isx oil cooler issue
Discussion in 'Trucks [ Eighteen Wheelers ]' started by mark319, Jan 19, 2010.
  1. mark319
    mark319 Bobtail Member
    Thanks Received:
    Jan 19, 2010
    we have a international truck with a cummins isx engine (not sure if cm870 or cm871-engine is a 2005). basically we are getting oil in the coolant. read up that this is an issue with these engines and i see people are saying its the oil cooler that's causing it. mostly want to know where the actual oil cooler is? is there a schematic online somewhere that shows the breakdown. and im guessing the turbo needs to come off. can it come off in one piece or does it need to be disassembled?
    are we looking at replacing the whole oil cooler or possibly just a gasket?
    should we pressure test the oil cooler?
    our mechanic is very skilled just has never torn this truck/engine down before.
  2. mark319
    Thanks Received:
    Jan 19, 2010
    here is a pic of the engine. is the horizontal tube marked with the pink square the housing for the oil cooler?
    is the blue square marking the turbo that needs to come off?
  3. mark319
    Thanks Received:
    Jan 19, 2010
  • Draft saved Draft deleted
