Cummins ISX oil leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by me myself and I, Dec 1, 2012.
  1. me myself and I
    me myself and I Medium Load Member
    330
    Thanks Received:
    86
    Oct 5, 2009
    vernon hills,Il
    I had that leak for a while. Between front cover and engine block behind air compresor. Tonight entire left side of the engine is oil covered. I quess I cant ignore it any longer. How much it'll set me back? It's a Volvo.
  2. truckmechanic
    truckmechanic Medium Load Member
    534
    Thanks Received:
    119
    Jan 14, 2012
    Hi Desert Ca
    I currently work at a cummins dealer just finished resealing a gear cover yesterday pretty big job according to the work order they charged customer 14,000.book calls for between 20-30 hours
  3. country29
    country29 Medium Load Member
    513
    Thanks Received:
    137
    Feb 27, 2010
    structure plate gasket, just did my 1st one and I had about 35hours in it, it was in a prostar. so that included removing bumper, hood, radiator assembly, all front cover components, and retiming the front gear train, vac/recharge a/c. its pretty labor intensive.
  4. truckmechanic
    534
    Thanks Received:
    119
    Jan 14, 2012
    Hi Desert Ca
    I just did one in 9200 about 20 hours I leave radiator in place,I belive you can on a Volvo to as long as not pulling the cams can get in the way but if you can save a few hours then why not
  5. Gear head
    Gear head Medium Load Member
    532
    Thanks Received:
    83
    Apr 1, 2012
    Belair,md
    Alot of time involved with taking it apart very little money in parts.
  6. me myself and I
    330
    Thanks Received:
    86
    Oct 5, 2009
    vernon hills,Il
    I've lucked out. It was leaking from base of oil dipstick tube. So 100 bucks later I got new ( and improved) dipstick tube, but I'll have to get the other leak fixed soon. So I wander what else can I get done when the cover is off. I'm thinking fan hub for sure. Any other suggestions? thing got 900k on it.
  • Draft saved Draft deleted
