The last couple trips I have found that if I am doing a long hake down a hill and my Rpms are a little high (between 1800 and 2000) my oil pressure will drop enough to cause engine to go into limp mode. If I keep Rpms under 1700. No issues. Any ideas? Anything I need to worry about?
Engine brake and oil pressure
Discussion in 'Volvo Forum' started by Morkable, May 3, 2016.
Those are pretty high rpms not sure why oil pressure would drop unless your so low on oil, the oil is being used for engine brake then sets a low oil warning off
most likely the O-rings for the oil supply in your eng brake.
Is your Jake sometimes inconsistent? -
Sorry. It's a d16. 625.
Kb3mmx. Can you explain inconsistent? As in engine braking power? -
That sounds like a winner. Are these orings hard to change?
