Fuel pressure or restriction gauge?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SpeedRacer, Feb 8, 2011.
  1. SpeedRacer
    SpeedRacer Light Load Member
    143
    Thanks Received:
    12
    Dec 4, 2007
    Tifton, Ga
    If I only have room for one gauge, either fuel pressure or restriction. Which is better to have? This is on a 6NZ C-15. Thoughts?
  2. Les2
    Les2 Road Train Member
    5,151
    Thanks Received:
    2,240
    Jul 25, 2008
    kicked back in my lazyboy...
    Whats the restriction gauge for, the air filter? If so go with the fuel pressure gauge. The air filter gauges aren't worth crap.
  3. SpeedRacer
    143
    Thanks Received:
    12
    Dec 4, 2007
    Tifton, Ga
    No, I already have air restriction gauge. I'm talking about fuel pressure or fuel restriction.
    Les2 Thanks this.
  4. Jfaulk99
    Jfaulk99 Road Train Member
    2,918
    Thanks Received:
    1,586
    May 16, 2009
    Couch
    Fuel pressure would be nice but I've never seen any of them last very long. (i.e. factory Pete) All of ours have fuel restriction gauges and seem to work well. Not really needed since I always change all filters at every oil change whether it's needed or not, but it will show if they get dirty.
  5. SpeedRacer
    143
    Thanks Received:
    12
    Dec 4, 2007
    Tifton, Ga
    I was looking at the Teltek gauges, both the pressure and restriction gauges are about the same price. Wouldn't you be able to notice restriction in using the pressure gauge as well? (maybe not as obvious) I change mine every service as well, but it would be nice to know if and when they need it. My thinking was with a pressure gauge I might see other problems as well instead of just restriction.
  6. Lilbit
    Lilbit Road Train Member
    16,545
    Thanks Received:
    12,181
    Aug 4, 2008
    Let me check my logbook
    Hey, SpeedRacer, you're missing something!
  7. SpeedRacer
    143
    Thanks Received:
    12
    Dec 4, 2007
    Tifton, Ga
    Kewl, that'll make for a great avatar. Thanks!
    Lilbit Thanks this.
  8. rbht
    rbht Heavy Load Member
    888
    Thanks Received:
    496
    Jan 23, 2010
    CT,NH
    I would go with the restriction gauge. I watch it all the time and it's saved me from dieing on the road when i saw it go up a few times. The fuel pressure guage at least in my truck bounces around like crazy and i can never get an accurate reading rom it.
  9. black_dog106
    black_dog106 Road Train Member
    1,406
    Thanks Received:
    476
    Mar 29, 2009
    Shelburne Falls, MA
    Just as RBHT said:
    Was running empty, so didnt need much power. Cold day and fuel was gelling up. Didnt feel it (yet) because wasnt using power, but restriction gauge showed it first. Pulled into next plaza and changed filter, problem solved. I have both gauges, but i would give up pressure gauge first...:biggrin_25517:
  10. SpeedRacer
    143
    Thanks Received:
    12
    Dec 4, 2007
    Tifton, Ga
    Good point, I'm leaning towards the restriction gauge. I guess both would be best, but maybe later when I find a place to put more gauges. I'm about out of dash space. I need to build a pod for gauges to sit on top of the dash huh? ;)
  • Draft saved Draft deleted
