gas shocks
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ColumbiaBoB, Jun 10, 2013.
  1. ColumbiaBoB
    ColumbiaBoB Light Load Member
    121
    Thanks Received:
    6
    May 3, 2011
    Des Moines, IA
    Hi, i'm looking to replace shocks on my '05 columbia with gas shocks, the problem is freightliner dealers i have visited/called don't have them all they have are gabriel oil shocks. Any help would be appreciated. Thx
  2. Helowrenchturn2
    Helowrenchturn2 Medium Load Member
    484
    Thanks Received:
    124
    Apr 23, 2013
    Should be able to take em to napa and get the number crossed for some gas shocks. A buddy just got a set for his western star at the Volvo place in Carlisle.
  3. rollin coal
    rollin coal Road Train Member
    7,489
    Thanks Received:
    8,355
    Mar 29, 2008
    TN
    Call a fleetpride, truck pro, or napa and have them cross reference those gabriel shocks.
  4. snowman_w900
    snowman_w900 Medium Load Member
    399
    Thanks Received:
    193
    Nov 25, 2010
    tell them you want to cross them over to the Monroe magnum 65 gas shocks. freightliner should be able to cross the number for you( if they feel like dealing with you).... or call Stengel Brothers out in PA. They can get ya what you need. 1-888-433-3149
    SHC Thanks this.
  5. beltrans
    beltrans Medium Load Member
    428
    Thanks Received:
    87
    Nov 26, 2008
    spokane wa
    Get OEM part numbers from your dealer.. Then go to this site http://www.monroeheavyduty.com/
    Go to Catalog and click on Interchange button. Enter OEM part number and click search... You will get Monroe part number you need.
  6. ColumbiaBoB
    121
    Thanks Received:
    6
    May 3, 2011
    Des Moines, IA
    Ok i got them #'s now what's better monroe gas or gabriel gas?
  7. beltrans
    428
    Thanks Received:
    87
    Nov 26, 2008
    spokane wa
    I would go with Monroe regardless...
  8. bigstank
    bigstank Light Load Member
    81
    Thanks Received:
    12
    Mar 4, 2013
    missouri
    Monroe gas charged all the way. Call any truck steering n axle shop will have them. Gabriel are junk and blow out after 25-50k miles
  9. SHC
    SHC Spoiled Rotten Brat O/O
    8,597
    Thanks Received:
    6,950
    Feb 26, 2011
    Westville, IN
    Monroe.... and the TA's carry Monroe shocks and it's $185 a set installed I believe??
  10. jason6541
    jason6541 Medium Load Member
    533
    Thanks Received:
    351
    Mar 5, 2012
    around
    Never pay to install shocks it's less than an hr job. Unless someone didn't use anti seize on the bolts when they went thru the metal sleeves on the shocks. Also don't forget your cab shocks they're only good for about a 100,000 m i. Use anti seize and new lock nuts on those bolts
  • Draft saved Draft deleted
