How to use a tire thumper
Discussion in 'Questions To Truckers From The General Public' started by Redcoat wife, Sep 13, 2008.
  1. Redcoat wife
    Redcoat wife Medium Load Member
    307
    Thanks Received:
    259
    Jul 27, 2008
    Tupelo, MS
    OK this is probably a dumb question but how exactly do you use a tire thumper? (And no I'm not talking about on somebody's head.)
    Do you hit the tire on the tread? On the sidewall? Does it matter? And what exactly are you looking for? The reaction of the thumper? Or are you listening for a certain sound?
  2. Lurchgs
    Lurchgs Road Train Member
    2,122
    Thanks Received:
    298
    Feb 13, 2008
    Denver, CO
    Hit the tire anywhere, but I find the tread works best for me.
    Basically you are listening to the sound it makes, and feeling way it reacts in your hand. A properly inflated tire will produce a sharper >>thwack<< sound when hit, and the thumper will bounce back sharply.
    If a tire is *significantly* under-inflated, the sound will be more of a dull thunk, and the thumper will not bounce back so well.
    It's not a good way to tell if the tire is 10 pounds low, but should show easily if the tire is 50 pounds low - that sorta thing.
  3. 25(2)+2
    12,594
    Thanks Received:
    10,434
    Sep 18, 2006
    the road less travelled
    I find that 'thumping' works best when the tires are warmed up, I use a 3 lb hammer, other uses for that as well. If it's really cold, thumping won't find a flat tire with certainty.
    dollylama, Cybergal and heyns57 Thank this.
  4. Donk
    Donk <strong>Have a Cup Of Concrete</strong>
    916
    Thanks Received:
    4,102
    Apr 27, 2008
    i use another way to quickly check tyres that i know were up.
    i push on the sidewall with my foot. doesnt produce even the degree of accuracy that a thumper does, but we arent allowed them here..
    So i carry a tyre guage!
  5. doubledragon5
    doubledragon5 Road Train Member
    2,911
    Thanks Received:
    3,886
    Jun 8, 2008
    Lewisville TX
    You will know if you have plenty of air by hitting it as hard as you can until it comes back and wacks you in the head.LOL The only way I check for properly inflated tires is with a tire guage...
  6. RickG
    RickG Road Train Member
    12,814
    Thanks Received:
    6,014
    Jul 22, 2008
    Owensboro , KY
    I forget what the movie was , it's been a while but I saw one of those truck movies that started having the driver go around the truck thumping the tires - including the front ones . :biggrin_2554:
  7. Add a truck driving job review
  8. Lilbit
    Lilbit Road Train Member
    16,545
    Thanks Received:
    12,154
    Aug 4, 2008
    Let me check my logbook
    My hubby uses a tire pressure gauge. My tire thumper from when I drove stays in my car, and it has one purpose - protection. That's mainly what it was for when I was driving rig too. I always used a tire pressure gauge.
    dollylama Thanks this.
  9. doubledragon5
    2,911
    Thanks Received:
    3,886
    Jun 8, 2008
    Lewisville TX
    Mine looks like a billy club, and it is in the car. The wife and daughters use it for protection as well..
  10. TrooperRat
    TrooperRat Medium Load Member
    460
    Thanks Received:
    87
    Dec 29, 2007
    Phoenix, AZ
    I just hit the tire tread with my breaker bar or kick the sidewall with my foot. Not an accurate way to tell if tires are property inflated, but definitely will let you know if a tire is flat or near flat.
  • Draft saved Draft deleted
