thanks I did check everything but no main cause... Summers are up so hopefully wouldn't be problem
Is it a battery problem or starter??
Discussion in 'Freightliner Forum' started by HORIZON2819, Mar 23, 2013.
Page 3 of 5
respect your years you have put in your mechanical knowledge... Comparatively I am new in this so I avoid stuff on my own for any other charges may occur
went to mechanic, says let the summers come and if the problem continues then will see..now as temp has gone up little bit, it starts fine now ...
I own it only 3 months now. Checked battery gauge before starting in morning it was 12.7 v and as soon as I start it went up to 14.0 v...
Go talk to the parts houses though and they'll be more than helpful to walk you through this stuff.HORIZON2819 Thanks this. -
If you can get to a PARTS SOURCE store ( owned by Canadia Tire ) they will do a load test on your batteries at no charge
Good Luck ! -
You didn't say what part of the country you're in ,or even what country his location shows Toronto Ont that is in Canada
parts stores DON'T know how to test batteries. NOR do they have the proper equipment.
anyone can test a battery with a 50 amp machine. even a 9 volt duracell will pass the test.
you need to pull 500 amps to properly test the batteries.
i explained the test procedure. NO parts stores follow that procedure.HORIZON2819 Thanks this.
Page 3 of 5
