ISX 450 fan clutch
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ejm, Dec 30, 2010.
  1. ejm
    ejm Bobtail Member
    16
    Thanks Received:
    5
    Dec 1, 2010
    If I understand correctly, the fan clutch releases with air applied? My fan never stops and I don't find a air leak. Any ideas or do I have the wrong concept?
  2. heavyhaulerss
    3,309
    Thanks Received:
    1,593
    Dec 23, 2009
    AL/TN BORDER
    could be the selenoid switch or a blown fan fuse.
  3. Smalltruck
    Smalltruck Light Load Member
    141
    Thanks Received:
    48
    Jul 3, 2010
    Elko, MN
    Some use air to release and others use air to lock. Some also have the ability to be locked on by screwing bolts into them. Cummins uses the ECM to ground out the fan clutch to make it work. A short in that part of the ECM will also cause it to stay on. First thiing is to put ait to the fan hub an see if it unlocks. If it does then the problem is elsewhere.
  4. ejm
    ejm Bobtail Member
    16
    Thanks Received:
    5
    Dec 1, 2010
    Thanks guys, gives me a good start.
  • Draft saved Draft deleted
