Maxxforce 10 to Commins conversion?
Discussion in 'International Forum' started by danlpt, Aug 24, 2016.
I think you'll need the longer hood with the isx 15 but if your pro star has it then yeah its doable a used isx is like 10k or so plus you'll need all the hardware and ecm but doable
Doable but probably cost prohibitive not only need to buy the engine but all the wiring harnesses, ECM programming bell housing, drive shaft would need to be fit or changed and god knows what else I'm forgetting
Different OEM wiring harness outside of cab, not sure about how much different inside. Could be a huge wiring nightmare. Different engine mounts, different fuel lines, different exhaust set up, different power steering line, different rad and air to air. Usually at this point it is no longer cost effective.
Best plan would be a write off with useable engine and accessories .. You most likely need the cac , rad , numerous engine brackets , wiring and other small stuff
