Meritor 12 speed auto
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Koerbs, Aug 10, 2009.
  1. Koerbs
    Koerbs Bobtail Member
    11
    Thanks Received:
    Aug 9, 2009
    Warroad, MN
    I am looking at buying a truck with 611,000 miles with a meritor 12 speed auto. I have never driven or heard much about auto transmission semi's.
    It is a 9400i ISX 400
    So, what is the life span of these transmissions? How much is a replacement unit?
    Thanks!!!
    :biggrin_25525:
  2. stranger
    stranger Road Train Member
    3,386
    Thanks Received:
    4,221
    Oct 10, 2006
    NC
    I don't know about the lifespan, but I did drive for a company that had several. They are smooth shifting, and the extra two gears are nice.
    However, the Meritor does NOT float the gears like the Eaton does. This means the clutch is depressed with each shift, wearing all releated parts with each shift. The company I was at used them behind C-13s, and experienced chrankshaft thrust bearing wear out in a short amount of miles using this transmission.
    Now, I have heard that the C-13 is known for thrust bearing problems, but the conanstant clutch useage made this much worse. The thrust bearing problem without a Meritor is a rumor, but the problems the company I worked for had using the Meritor were real.
    That's all I know. Hope it helps.
    Baack Thanks this.
  3. Koerbs
    11
    Thanks Received:
    Aug 9, 2009
    Warroad, MN
    I don't see a clutch pedal.....
  4. Koerbs
    11
    Thanks Received:
    Aug 9, 2009
    Warroad, MN
  5. stranger
    3,386
    Thanks Received:
    4,221
    Oct 10, 2006
    NC
    The transmission clutches itself with an air operated slave cylinder. It's a two pedal fully automatic operation.
    I sometimes had to stop and restart the truck to get the Meritor to reset itself after it would lose its mind every so often when using it manually.
  6. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    Thanks Received:
    120
    Apr 28, 2009
    Cincinnati, ohio
    i would put money on it that the clutch has been replaced once already, if u can get them to print off the clutch abuse info, scan it and post it on here. i will be able to tell u if the clutch is good or not. thats the biggest problem with those trans is the clutch. when u test drive make sure it shifts, takes off from a stop and comes to a stop smooth.
  7. Add a truck driving job review
  8. cat from the valley
    cat from the valley Medium Load Member
    468
    Thanks Received:
    29
    Dec 8, 2008
    jamaica
  9. TURKER
    TURKER Medium Load Member
    345
    Thanks Received:
    94
    Aug 11, 2009
    Raleigh NC
    Because the auto trans. I and Many drivers dont like them!
  10. The Iron Man
    The Iron Man Bobtail Member
    Thanks Received:
    Oct 17, 2015
  11. The Iron Man
    Thanks Received:
    Oct 17, 2015
    I also have had problems with this transmission. I just started to drive with this transmission. One of the problems I have had is it gets stuck in third gear when the transmission is in automatic.
  • Draft saved Draft deleted
